Hi all,
Well, finally getting the conversion up in the air, at least that was the plan.
I had everything on the tower and was preparing for a test lift and was gonna let the rig sit hanging out of the cradle for a day or so as a test of cables and such... (probably not necessary, but that's just me) anyway, I was pulling ever so slowly forward with the tractor and the jenny and blade set didn't seem to be moving... uh oh, locked up the tractor after backing back to start point and got off to look...
Well, as luck would have it, my gin pole was the weakest link it seems... it took a big "wowww" and said bye bye... shoot...
But, after a moment of reflection... I need to be grateful that it happened as it did... could have been half way up and man, that would have been a disaster...
My lift is:
tower 65' 350lbs
jenny 100lbs
12' blades and mounts 70lbs
miscellaneous hardware (cable, clamps etc) 50lbs
4 sets of 4 guys
gin pole was 2.5" schedule 40 30' long with support lines at center to ground anchors points at sides, it wowwwed towards the tower not the lifting side? Prior to the lift I rechecked (again) all the tensions on the cables to be sure everything was equal. By the way, this tower was up for over three years with my other jenny on it, this is not a new set up just beefed up a bit for the new conversion.
the tower is three legs pivot at the bottom gin pole attached at tower base (fixed to tower as in picture when in use)
Tower Base with gin pole attached
Tower at rest on stands
Wondering if anyone would be able to offer some thoughts on this? I've studied DanB's 20 footer and how he worked that one out (very nice I might add) so I'm thinking that I need some idea of what would be an appropriate dimension and wall or type of pipe to use for this lift? Perhaps something thinner walled but larger diameter like 4 or 5" schedule 20 ??
This setup has a chevy small block in each ground anchor hole with cement (a piston missing for a ground anchor to pass through in each).
Would also like to know just what kind of weight or force is necessary to lift this bundle from a math perspective when considering how much it weighs and the length and all?? (What forces are really at work on this thing when lifting?)
Thanks to everyone for all the info and help you give, especially my friend Zubbly who helped me get this thing together (miss him).
Best,
behoof
