Author Topic: Yawl Bearing  (Read 1350 times)
ibedonc
Yawl Bearing
« on: June 16, 2004, 08:30:40 PM »
I think it will work with a little grease and a set screw to keep it from tighting down
« Last Edit: June 16, 2004, 08:30:40 PM by (unknown) »
ibedonc
Re: Yawl Bearing
« Reply #1 on: June 16, 2004, 09:36:59 PM »
I forgot to add that it is for a small tredmill gen
« Last Edit: June 16, 2004, 09:36:59 PM by ibedonc »
Victor
Re: Yawl Bearing
« Reply #2 on: June 16, 2004, 10:15:01 PM »
Hi Don,
 Thats yaw bearing. By the way  the new slang for us wind nuts is  yaw heads.
Victor
« Last Edit: June 16, 2004, 10:15:01 PM by Victor »
ibedonc
Re: Yawl Bearing
« Reply #3 on: June 17, 2004, 05:52:02 AM »
oh well since I am from Texas , I guess that it is the texan way of spelling it
« Last Edit: June 17, 2004, 05:52:02 AM by ibedonc »
old55olds
Re: Yawl Bearing
« Reply #4 on: June 17, 2004, 10:04:33 AM »
You might get away with it. But you are going to have all the thrust against that small flange on one side only. This is going to bind unless you Texans have better grease than us Canuckistans.  I would think better a collar and then pipe over pipe.
Retain the top with another collar. A grease fitting and away you go.
ken
« Last Edit: June 17, 2004, 10:04:33 AM by old55olds »
ibedonc
Re: Yawl Bearing
« Reply #5 on: June 17, 2004, 01:11:22 PM »
I going to test this weekend , it is on a 130v 6amp Tredmail motor with 3 hornet blades
not very heavy
« Last Edit: June 17, 2004, 01:11:22 PM by ibedonc »
ibedonc
Re: Yawl Bearing
« Reply #6 on: June 17, 2004, 01:15:51 PM »
TreadMill ( not Tredmail) really got start watching my spelling
« Last Edit: June 17, 2004, 01:15:51 PM by ibedonc »
