Author Topic: L System Papst 'made in germany'  (Read 1622 times)
juiced
« on: January 20, 2005, 05:47:42 PM »
I found an old machine called a 'Stenorette'. Its made in Great Britan, with many pieces that are German. Actually, the gutz are mostly German.
 What I Know:
  Model Name: Embassy/2
  US Patent No. 3,057.570
  US Distrib: DeJUA
  115v 32w 60hz/cps (cycle per second?)
 This machine was some old recoreder of some sort. Looked similar to a reel to reel.
 I can't get the motor open but rather than having an axle/coils on bearings; it has a drum with a fixed axle (to the drum). The entire drum rotates, while the base has 3 screw-mounts sticking out, under the coils.
  So:
- = Axle
[ = drum
< = coils
| = Mount
= = Wires
  -[ Rotates around <|
   <|= is inside of -[
   <|= is fixed and has the coil/wires
   Its about 4" across and 4" high. There is a plastic, glued in cap the i suspect would allow me to disassemble the device.
     Im sure i just typed all this for another fridge magnet :p
   Happy new guys! Many a free KW to you!
                    Juiced
« Last Edit: January 20, 2005, 05:47:42 PM by (unknown) »
