Author Topic: Question for Jerry  (Read 1240 times)
Gary D
Question for Jerry
« on: February 03, 2005, 04:32:08 PM »
Jerry, your disc machine closely matches my older Winco's output! I bet it's a lot quieter than the 2 blade 6 footer too. Great job!
 What gauge wire did you use? Forgive me if it was stated, couldn't find it.
 I was wondering if you thought of changing your disc stator? Hugh's large turbine spec's use a 5 phase ten coil arrangement. Two coils per phase. Looks like you have room for ten coils in there. If you used this arrangement with larger wire and split the 300 turns in half, possibly you'd get a bit of an improvement overall? Or add a few turns per coil for a slightly lower cutin?
 Your blades seem less prone to stall since they are workng on many various horsepower units. Don't know if building a new stator is worth your time or not, seems like you could get a bit more copper in there... Again Great Work!  Gary D.
« Last Edit: February 03, 2005, 04:32:08 PM by (unknown) »
