Author Topic: Wind Generator  (Read 1370 times)
zymurgy
Wind Generator
« on: March 29, 2005, 06:13:23 PM »
Hello. I am trying to make a miniature wind generator for a project in one of my classes. I am in grade 12 and would like some help. I have a blade design, the NACA 4412. I would like to know how should i rotate it for maximum efficiency. I would also like to know the best way to attach the blades to the center hub. If there are any sites that you have found on your travels, please tell me. All help will be greatly appreciated.
                   ~Zymurgy~
« Last Edit: March 29, 2005, 06:13:23 PM by (unknown) »
PHinker
Re: Wind Generator
« Reply #1 on: March 29, 2005, 11:55:19 AM »
You might want to spend a little time searching this forum since most (if not all) the questions you'll have will have been broached here at one time or another.
Having just helped my daughter finish a school project on wind generators here are a couple of questions you may (or may not) have thought of so far:
   * How much power is required for your project?  A small wind generator is nice for demonstration purposes but if you have a specific use for the generated power you will want to be sure that your generator can meet the needs.  For example, the demo is going to light some lights and spin a merry-go-round.  There's not a lot of power available to a set of blades with only 12" or so swept area.  (Very) roughly
      Power(watts) = 0.0012 * V^3 * D^2
      where V is the wind speed in mph
            D is rotor diameter in feet
   * How will you drive the generator blades?  Will this unit be placed in the wind or will you spin the blades by hand or ???
   * Are you going to build your own generator or use an DC motor?  Most DC motors like high RPMs which impacts your blade TSR.
Good luck with your project.
Paul
« Last Edit: March 29, 2005, 11:55:19 AM by PHinker »
zymurgy
Re: Wind Generator
« Reply #2 on: March 30, 2005, 11:22:05 AM »
Thank you Paul. i have found a lot of information now that i have the time to search the site. i have to talk t o my teacher to see if he agrees with what i have found. I will try to keep this updated. Thank you :)
                       ~Zymurgy~
« Last Edit: March 30, 2005, 11:22:05 AM by zymurgy »
pickles87
Re: Wind Generator
« Reply #3 on: March 31, 2005, 11:05:15 AM »
well i am looking for the exact same thing so i dont know what to suggest other than when you find out please tell me. thanx
« Last Edit: March 31, 2005, 11:05:15 AM by pickles87 »
Re: Wind Generator
« Reply #4 on: March 31, 2005, 04:38:19 PM »
If the BLADES are just a part of the total project, you should search this board for Zubwoofer and Sputnic. Both types are cheap and easy to make, and are functional.
Flat blades work OK too.
http://www.fieldlines.com/story/2005/1/22/235048/303
Even a 20" window fan blade works.
http://www.fieldlines.com/story/2005/3/11/43928/3227
Here is a little about zubwoofer's and a simple hub.
http://www.fieldlines.com/story/2004/12/18/062/90125
This is easy,
http://homepage.ntlworld.com/s.amesbury/props.html
A few hours searching here will get you more usable info than anywhere else!
Let us know what you end up wth,
« Last Edit: March 31, 2005, 04:38:19 PM by ghurd »
