Author Topic: Which charge controller for a 500 watt windmill  (Read 1154 times)
Matrix1000
« on: September 15, 2005, 05:37:35 AM »
I built a 12volt windmill from Hugh's plans and I'm assuming it will make about 500 watts max. I got some batteries from the local cart shop and plan on adding a solar panel in the near future. All I'm missing is a charge controller.
Are there any charge controllers, that aren't really expensive, that stand out?
If I were to use a separate charge controller for the mill alone, what would be a good choice.
« Last Edit: September 15, 2005, 05:37:35 AM by (unknown) »
DanB
    • otherpower.com
Re: Which charge controller for a 500 watt windmil
« Reply #1 on: September 15, 2005, 07:01:39 AM »
If you built Hughs 8' machine, I expect you'll see 1000 watts or more at times.
If its 12V I'd suggest a Trace C60
For 24 or 48V I think a C40 would be fine.  A C40 would probably work OK at 12V too, they can handle up to 80 amps for short periods I believe - but at the lower voltage Id probably go with the larger controller.
Youll also need an appropriate dump load (heater).
« Last Edit: September 15, 2005, 07:01:39 AM by DanB »
georgeodjungle
3,600 watt
« Reply #2 on: September 15, 2005, 04:37:39 PM »
i'm using a sea-50 and like it alot.
there's no bells or whistles just a black box and 4 wires.
you could get them for about $70 and another $30 for a 300 amp solenoid.
so i put a led on the solenoid to tell me when it's dumping.
« Last Edit: September 15, 2005, 04:37:39 PM by georgeodjungle »
scoraigwind
    • www.scoraigwind.co.uk
« Reply #3 on: September 15, 2005, 05:20:54 PM »
The Morningstar Tristar controllers are good.  they are like the c series but have a lot of more upto date featues.  And they respond much faster in gusts.
« Last Edit: September 15, 2005, 05:20:54 PM by scoraigwind »
