In case it isn't clear from the other posters:
A typical horizontal-axis machine has a blade that is an airfoil and "flys" in the wind - at a tip speed several times the wind speed - getting extra pull from the lift of the air as it goes past the curve of the blade. It's much like an airplane wing, and JUST like a propellor (except the curved side is on the opposite side of the blade).
Some of these mills are designed so that, when the wind speed is too high (AND the mill is under load) the blades will "stall" - just like an airplane that has been put into too rapid a climb for its current airspeed, or a sailboat "pinching" to closely to the wind. The airstream detaches from part of the curved backside of the blade and "peels off", trailing a string of vortices downwind. The lift is reduced, keeping the blade from overspeeding. (Again: IF the mill is under load - it will typically still overspeed and perhaps disintegrate, throwing blades heavier than baseball bats across the yard at an appreciable fraction of the speed of sound, if it is NOT loaded.)
The vortices, however, turn an appreciable fraction of that lost energy into sound. A stalling mill sounds much like a helicopter in rapid flight - for the same reason. You don't want a stall-regulated mill in your neighborhood if you like peace and quiet - or, if you have neighbors, you still want your mill to be standing next year, all the paint to still be on your car, your barn unburned, ...
Now if you live miles from anyone else and are deaf...
