Author Topic: anemometer  (Read 748 times)
shawah
anemometer
« on: October 06, 2005, 06:35:49 PM »
hi, this is my first post, I want to install an anemometer on my farm to collect wind data velocity and direction, can someone here help me with drawings in making/errecting GI pipe mast, thanks for an early input
best regards
« Last Edit: October 06, 2005, 06:35:49 PM by (unknown) »
Oso
Re: anemometer
« Reply #1 on: October 06, 2005, 03:32:10 PM »
You need to supply a little more info. Like just how high is this mast supposed to be ?  Do you already have the GI pipe, so are we constrained to a certain diameter ?
Actually, I would give strong consideration to buying a tower for a wind turbine like the airX, and using that for my anemometer.  They are faily cheap and the used tower will have resale value, where the home made mast will only have scrap value.
« Last Edit: October 06, 2005, 03:32:10 PM by Oso »
wpowokal
Re: anemometer
« Reply #2 on: October 06, 2005, 06:10:17 PM »
Shawah, the anemometer mast needs to be 30 feet which is standard measuring height.
In my experience a stand alone pipe will need to be at absolute minimum 1 1/4" x 20' + 1" x 10'. as well as guy wires at the 20' mark as a minimum.
Anything less will see you measuring the ground wind speed in strong winds, that's after the pipes have doubled over.
allan down under
« Last Edit: October 06, 2005, 06:10:17 PM by wpowokal »
shawah
Re: anemometer
« Reply #3 on: October 08, 2005, 01:09:00 PM »
thanks
« Last Edit: October 08, 2005, 01:09:00 PM by shawah »
shawah
Re: anemometer
« Reply #4 on: October 08, 2005, 01:13:11 PM »
I am thinking to take readings at 30 feet, I have the GI pipe 1.5 inch and 2 inch, bit confused to calculate the length of guy wire, a sketch will be appreciated
thanks
« Last Edit: October 08, 2005, 01:13:11 PM by shawah »
