Fieldlines.com: The Otherpower discussion board
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Oil sucks, wind blows.
Home
Help
Search
Members
View the memberlist
Search For Members
Hall of Fame
Register
Currently debugging, strange errors may occur. Sorry for the inconvenience.
Homebrewed Electricity
Wind
Which Winch ? Photo ID ?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Which Winch ? Photo ID ? (Read 748 times)
Dave B
Hero Member
Country:
on:
December 31, 2005, 05:27:27 AM »
I'm trying to ID the worm drive winch the photos show. The original spec. plate is missing and the only numbers I see on it are 2384 on the casting and 2385 on the drum / spool. I plan to use this for my tilt tower. It weighs 65 lbs has a 10" wide drum and was wound with 3/8" wire rope. 48:1 reduction, 3/4" worm shaft, 6" diameter main gear and 7" diameter spool ends with 2 1/2" inside diameter spool. I believe it originally had a manual crank and or a small sprocket for a motor drive. Recently it looks like at least a 1/2" drill may have been chucked onto the input shaft also. I plan to dismantle it and check everything but so far it looks in very good shape, it will need a new cover gasket and of course 90W for the gearbox when I get it back together. It looks like "John Deer" green but that may not mean anything and I believe it was used at a silo ? It would be interesting to know the make and specs. on this unit, I have searched extensively finding similar but no match. Maybe someone out there can help ? Thank you, Dave B.
Last Edit: December 31, 2005, 05:27:27 AM by (unknown)
Logged
DCB Energy Systems
http://dcbenergy.com/
jlt
Sr. Member
Re: Which Winch ? Photo ID ?
Reply #1 on:
December 30, 2005, 10:40:24 PM »
IT looks a lot like military winch off 2-1/2 tontruck
Last Edit: December 30, 2005, 10:40:24 PM by jlt
Logged
Print
Pages: [
1
Go Up
« previous
next »
Wind
