hi iFred!
i have an industrial duty Leeson 1.5 hp (1725 rpm full load) 180 volt pm dc motor. it has a 6205 bearing in the drive end and a 6203 bearing in the non drive end. the output shaft is 7/8 inch diam. i often got 30-35 amp output into a 12 volt batt bank.
i flew it for a while with a 2 blade 9 foot prop. the shutter from the 2 blade eventually tore the motor's base to pieces. i welded a new base to the frame.
when the base broke, it allowed the motor to tilt down and caused a blade strike on the tower shattering the prop to pieces. (no more 2 bladers for me)
the bearings were however still in perfect shape and thrust seems to have no problems to date on any of the gennys i have made. those ball bearings will take more thrust than many people beleive they can. you can get the specs on any size ball bearing from a bearing supply house.
my current genny that i experiment with the most is a 1.5 hp induction conversion and now running an 8 foot prop on it. i did for quite some time have an 11 foot diam prop on it. actual running time on this unit is more than 2 years. bearings are still in perfect shape. i think the greatest factor in bearing longevity is good balance of the prop. i generally balance the prop on another motor shaft that has not been converted.
your shafts are probably 5/8 inch diam. i drill and tap a 5/16 inch hole about 1.25 inches deep into the end of the shaft. my blades are sandwiched between 2 steel plates and then i put a bolt directly through the 2 blade hubs and directly into the shaft. it makes a very secure mounting.
6 foot diam 3 blade for the 1/2 hp and 8 foot 3 blade for the 1 hp should work out well.
here on pages 21-23 of my album, you can see how i assemble a 2 meter prop with 2 steel plates and a hub for a 5/8 shaft. you can also see that i use a pendulum weight for balancing. http://www.anotherpower.com/gallery/zubbly?page=21
i think pm dc motors make great little gennys and actually get overlooked a bit too much in my opinion. if the commutator and brushes are in good shape, they should give a very long service before any attention is needed.
also, i did fly an ametek 30 volt model for a while. the prop was a 54 inch 3 blade unit. i had it on a 50 foot tower and that unit totally screamed until the brushes wore out and messed up the commutator. ball bearings in it were actually very small, but they were still in perfect shape when the unit came out of service.
by the way, the weld on hubs i use come from "Princess Auto Supply", available in most bore sizes and are also keyed. cheap as hell and work well. there should be one of those stores in your area.
hope this info helps you iFred.
have fun!
zubbly
