Author Topic: small wind generator with variable pitch blades  (Read 5080 times)
canadianfred
« on: September 18, 2006, 04:25:46 PM »
I was at http://www.ecoexpo.ca on the weekend and saw a wind turbine from http://www.vpturbines.com
This is a small windmill that uses variable pitch blades.
You can almost make out the mechanism here: http://www.vpturbines.com/html/details_0.html
I wish I had taken my camera with to the show, because they had one there, with the nose cone off, so you could get a clear look at the mechanism.
It doesn't look that hard to make, for someone with access to a machine shop. The hard part would be finding springs of the right strength to offset the forces acting on the blades as the wind speed increases.
« Last Edit: September 18, 2006, 04:25:46 PM by (unknown) »
drdongle
« Reply #1 on: September 18, 2006, 03:56:39 PM »
Looks like another Co. using a modified auto alternator.
« Last Edit: September 18, 2006, 03:56:39 PM by drdongle »
paradigmdesign
Re: small wind generator with variable pitch blade
« Reply #2 on: September 21, 2006, 06:55:04 AM »
Yeah, I think it is funny when these "companies" spend so much time on there gimmick, and marketing, and so much time avoiding doing what many of us here do all the time, which is build the actual genny.
« Last Edit: September 21, 2006, 06:55:04 AM by paradigmdesign »
xymox
Re: small wind generator with variable pitch blades
« Reply #3 on: November 17, 2011, 01:43:37 AM »
I saw their design and I worked out the following which seems to be allot simplier.
http://fieldlines.com/board/index.php/topic,138013.msg997928.html#msg997928
