Have been working on an anemometer I can use to start recoeding the variations in the wind over the course of the year.
The hub assembly is an old VCR head scrounged from a broken VCR, The housing is a piece of PVC guttering pipe, there is a small rotor from another motor I found in the VCR unwound and now cradling a fragment of NDFEB. The cups are made from the tops of a roll on deodorant and is good and thick, very sturdy and responsive..
I will use a reed relay glued to the inside of the housing in line with the magnet. A 1-wire dual counter (http://www.hobby-boards.com/catalog/product_info.php?cPath=22&products_id=42)
will count the number of switch closures. This info will be sent back to the PC (later an standalone network Hard Drive)and logged.
Using Java the inputs from this will be converted into windspeed in mph.
Well thats the Idea...
I was wondering if others have gone down this route before and how they went about calibrating, ive read plenty on the calm day driving with the anemometer on a stick, this would work fine.
I will need a rough graph of speed to rpm
However in the Java program there is a formula to convert switch closures into mph:
Windspeed = counts / time * (N)
where N is a number to convert the rotation into windspeed, Counts is the number of switch closures
My magnet rotates 2cm from the axis
I can get the "N" by trial and error but wanted to see if anyone had better ideas than me (shouldnt be too difficult)
Will
Pics arent over 50k each, size a little large tho, hope it isnt a problem.
