Hi Bob.
My first Lakota was a used unit also. One of the first things I did with was a wind test in my S-10 PU.
I was disapointed in that first wind test. The genny was stalling bad. It took 15 mph just to brake it loose and get it going.
I Talked to the Lakota tech guy. He was a great help, he talked me through some things and sent me the large owners manual with more info then I thought posable.
The Lakota has 4 posable wireing scheems. Areomag calls these.
High wind wire conections (mod))0
Conenect the #1,#4,#5 and the #0 wires together
Phase 1: Connect the C and the #6 wires to one of the black leads going to the brushes.
Phase 2: Connect the B and the #3 wires to one of the black leads going to the brushes.
Phase 3: Connect the A and the #2 wires to one of the black leads going to the brushes.
Next.
Medium high wire connections (mod 1))0
Connect the #4,#5 and the 0 wires together.
1st Serial connection #1 and #2 wires.
Phase 2: Connect the B and the #3 wires To one of the black leads going to the brushes.
Phase 3: Connect the A and the the last black wires going to the brushes.
Next.
Medium low wind wire connections (mod 2))0
Connect the #5 and the 0 wires together.
2nd Serial connection #3 and #4 wires.
Phase 1: connect the C and the #6 wires to one of the black leads going to the brushes.
Phase 2: connect the B wire and one of the black leads going to the brushes.
Phase 3: connect the A wire to the last black lead going to the brushes.
Next
Low wind wire connection (mod 3))0
Cap the 0 wire
- st Serial connection #1 and #2 wires.
- nd Serial connection #3 and #4 wires.
- rd Serial connection #5 and #6 wires.
Phase 1: connect the C wire to one of the black leads going to the brushes.
Phase 2: connect the B wire to one of the black leads going to the brushes.
Phase 3: connect the A wire to one of the black leads going to the brushes.
I prefure the High wind connection. It has the easyest startup, It also will makes the most power. I had received the used alt set in the Low wind (mod 3))0 connection.
After reconfiguring it in the (mod 0))0 congiguration it started charging at 6 mph and by 20 mph it was doing 60 amps.
During one of our 50 mph wind storms (tower mounted) I was seeing well over 2000 watts from the Lakota. The furling is adjustable by the spring tesion adjusters.
Aeromag has stated the this unit has been tested to 120 mph. It resently survived our last 80 mph storm without a problem even though I locked the unit down so it could not furl out of the wind. I check just one phase ac with a clampon ac amp meter it was reading 58 amps. I knew the DC output after the rectifiers was much higher then that.
This alt is a 3 phase 8 pole. Curved NEOs. Those blades are a builtyfull thing. I used a set on one of my motor conversion and was seeing 2025 watts at 30 mph with cut in around 6 mph.
I will only use the high wind connection but the book says if you want to use the 24 volt for 48 volt try one of the lower wind connection.
I know if you short the leads it very hard to turn.
Sorry I don't have RPM info but now that you know pole #s you can take some HZ/ rpm readings.
Here are some color codes on those wires.
For high wind speed connection.
Blue#1
Orange#4
Gray#5.............Connect these to the Green #0 wire.
Black C and Gray #6 to a brush wire.
White B and orange #3 to a brush wire.
Red A and Blue#2 to a brush wire.
Blue and orange are used twice. Its been a long time but I think there #erd.
If not, take note of how and to what wires there connected to now and mark them.
Good luck.
Keep us posted.
