Hi guys!
I've got a large wound rotor generator, from a rather large windmill. Unfortunately it's busted, beyond possible repair. But to convert another motor for it I really needed to study the blown one further, to learn how the rotor is connected.
The generator I'm studying is an old 33kW, 950rpm(6pole) motor. It's been converted to work like a car alternator, supply DC to the field coil, and it makes 3 phase AC current. The beauty of this design is, that the windmill output is very easily controlled by varying the current supplied to the rotor, (or field coil). The stator is just like in a normal induction motor.
This is the generator I'm talking about. Most likely due to too high RPM's the field windings had came loose, and caused a catastrophic failure. It's got 3 sliprings in the rear part of it, originally used for soft starting purposes.
Finally after almost a days work the rotor is out of the motor. It has 72 slots on it, each slot has 4 turns of wire in it. Each coil in the rotor has 16 turns, so it occupies 4+4 slots. (4 going forward, and 4 coming back) I'll call these sets of 4 slots "bundles", so there is a total of 18 bundles in it. These coils of 16 turns are obviously wound in the factory, and they have not been tampered with. Instead, all that has been done is that the coils start and end leads have been reconnected.
Part of an old note, made by the guy who had done the conversion. The numbers there state the bundles, for example 1 means the start of coil 1 and 4 means the end of coil 1. It's rather confusing, but I hope you can follow. The dotted lines state about the required changes in the original connections. It would be easier to
understand if each of the coils where current runs clockwise would be first wired up in series, then the ones where current runs clockwise after that. But this picture shows how to do the process with minimal changes to the original winding. Also in the drawing is shown the 6 magnetic poles formed, 4 bundles make up a single pole.
I drew a picture that hopefully makes it more clear. Basically this tells how the coils sit in the slots on the rotor. Remember, each slot has 4 turns on it, though there is only 4 turns showing it is 4x4=16 turns in that coil.
Another picture that clarifies more the bundles and how the magnetic poles are formed. 4 bundles form a single pole. The connections between the bundles is not shown, they are all pictured in the drawing (in the note)
Anyways, a long post, but I hope if someone has one of these old motors can now find some good use for it
