Author Topic: rotor thickness  (Read 755 times)
oregon wind
rotor thickness
« on: May 08, 2008, 07:38:11 AM »
Typically 1/2" steel would be used for the rotors on Hughe Piggots 12' turbine.  Can anyone think of any disadvantages for using 5/8" other than weight.  I have some surplus.
« Last Edit: May 08, 2008, 07:38:11 AM by (unknown) »
Sparky01
Re: rotor thickness
« Reply #1 on: May 08, 2008, 06:20:19 AM »
There is nothing other than added weight that I can see as being an issue. Usually the issue is going too thin with mag rotors, and having issues with flux losses and structural integrity. So I see this as just a little overkill, whick will not hurt a thing.
« Last Edit: May 08, 2008, 06:20:19 AM by Sparky01 »
mbeland
Re: rotor thickness
« Reply #2 on: May 08, 2008, 06:32:33 AM »
You could also start with 5/8" and have them turned to make sure they are true.
Martin
« Last Edit: May 08, 2008, 06:32:33 AM by mbeland »
Sparky01
Re: rotor thickness
« Reply #3 on: May 08, 2008, 07:40:10 AM »
Yes the one I am building now will be counterbored 1/16" where the magnets are mounted to help them from sliding outward from centrifical forces.
« Last Edit: May 08, 2008, 07:40:10 AM by Sparky01 »
