Author Topic: Cute comic.  (Read 740 times)
Cute comic.
« on: September 22, 2008, 05:07:36 AM »
Found a cute windpower refrence in the net comic Kevin and Kell.
(They've had a few other alternative energy bits in the past, too.)
Too true about the homeowners' association.  (Though in my case it's the county board.)
« Last Edit: September 22, 2008, 05:07:36 AM by (unknown) »
harley1782000
  • I thought so too.....
Re: Cute comic.
« Reply #1 on: September 21, 2008, 11:54:21 PM »
All to true!!!  The BS I would have to go threw just to put a tower up.  Not worth it.
Jim
« Last Edit: September 21, 2008, 11:54:21 PM by harley1782000 »
Re: Cute comic.
« Reply #2 on: September 22, 2008, 05:55:06 AM »
 Money saved is always a good angle as most of these clowns are into that . If you can put up some type of genset long enough to get data that will save money  none of the covenants really apply at least to logical on lookers . As far as government goes screw em put it up make them tell you what's wrong with the install . If all national codes are met alot of times your good to go. You can use a structure or out building to build your genset around .Slide that through the approval process and carry on . If your waiting for the walls to come down take a number . Put it up and let em bitch . The oposition will boil down to a small groupe that likes money more than trouble .
« Last Edit: September 22, 2008, 05:55:06 AM by tecker »
