You have been asking a lot of questions for a while and I guessed you were only telling us half the story.
At least you seem to have chosen to keep your blades wide and with a lot of twist at the root, something that is pointless and wasteful of timber for an axial air gap machine but which may be necessary for you to get a decent start up with an iron cored machine with lots of flux.
Your power curve is into a resistive load so I have no idea of how it will load into a battery ( which I assume you are using at that low voltage).
Unless you do a run into a battery then I have no idea if you are too powerful or not.
Similarly I have no idea if this resistive load is single or 3 phase but as you only mention one resistor I assume it is single phase unless you used a 3 phase bridge with the resistor on the dc side ( so little information as usual)
If the alternator is too powerful then some sort of loading device that matches the load to what the prop can produce will work if it does the load match at good efficiency. I have no idea what your inverter thing is or what it does, if it works something like the grid tie inverters then yes it should be fine. I am not aware of anything commercially available for battery charging that does this job and if it was feeding a battery then it would not be called an inverter.
If you want any more help you will have to give all the information in future, asking bits of questions in isolation is very risky and may not get you an answer useful to your requirement.
You seem to be going the mppt route while asking about blades and other things as though you were building an axial, the loading conditions have no similarity.
If your internal resistance of that alternator is 25 ohms as you suggest then I seriously doubt that it will be too powerful for the blades and for mppt working the maximum power transfer theorem is a snare and delusion and you want very high alternator efficiency not 50%.
Just imagine a 500MW power station running at 50% and dumping 500MW from the alternator as heat just to extract maximum power ( no I don't think so).
