Hi
I had my turbine down today to up-rate the supply cable and increase the height (it was just over 18 foot). I have now put it back up to nearly 30 foot. Over the last couple of months I have had it at 12 foot, it worked well but only when it was pointing in one direction, other than that it was snapping back and forth on the yaw bearing, then at the 18 foot point, it produced less power than the 12 foot point, often sitting just below the point at which it charges, as the load came on it did not get enough wind to push it into charging, and again swinging about on the yaw bearing.
At 30 foot it swings gently on the yaw bearing, it starts turning earlier, and hopefully over the next couple of days I will see how it charges.
I would not have thought getting it just 6 foot above the gutter height on my house roof would make such a difference, or is it getting it just below the gutter height would destroy totaly any form of laminar flow in the wind.
I know various people on here have told me I was wasting my time with a low mast height, some times quite robustly, but you can't beat seeing it for yourself.
I wonder if a 40 foot latice tower would be a bit over the top to ask for at Christmas.....
