Hi Bay,
Me again,
you will,notice on the rotoer shaft there is not a stepped area on your rotor's shaft that goes inside the PMA, If it were so, the shaft could have been machined to do without the inside spacer bushing, by having an area on the shaft to prevent the "Over travel" brought on by when the outside nut is being tightened. As it stands now, the shaft is the same diameter of the faceplate's bering inside diameter.... And remains that diameter until it is at the face of the rotor. Thus the need for the spacer between the rotor and the inside of the faceplate to stop this "over travel"
All the best,
Gavin
