Author Topic: Advice needed building a dump load for 10' windmill  (Read 7568 times)
Tink
Re: C60 setting
« Reply #33 on: November 13, 2009, 10:06:11 AM »
ghurd,
I have the C60 I'm using for the solar panels set for bulk at 29.2 volts so what should I set the 2nd C60 for that I'm using for the diversion load? Sorry if this is a dumb question but I'm a little confused...should I go a little above or below 29.2 volts? And another maby dumb question...I'm assuming there is no danger to mount this diversion load in the battery shed is there? Here is a photo of the final install at least for testing. The yellow metal container at the bottom of the photo is the Crown 935 amph forklift battery.
http://www.fieldlines.com/images/scimages/13185/IMG_0167.JPG
Thanks, again
Tink
« Last Edit: November 13, 2009, 10:06:11 AM by Tink »
Re: C60 setting
« Reply #34 on: November 13, 2009, 11:27:25 AM »
Set the diversion controller a bit higher than the solar controller.
Should not be any problem with the load in the battery shed.
« Last Edit: November 13, 2009, 11:27:25 AM by ghurd »
Tink
Re: C60 setting
« Reply #35 on: November 14, 2009, 08:22:16 AM »
ghurd,
Thanks for all the great advice!
Tink
« Last Edit: November 14, 2009, 08:22:16 AM by Tink »
