Author Topic: How to test RAM chip?  (Read 1870 times)
sian
« on: January 10, 2006, 11:10:23 PM »
Hello!!
In need of some help please! I have a 32k EEPROM chip (Xicor X28HC265P-12) and a 512K RAM chip (HM62851CLP-7) on my circuit board and I want to test if they are faulty.
Is there any way to isolate the chips to test that they are working and that i havent blown one of them... which is quite possible with me!
Any suggestions would be awesome!!
Thankyou,
Sian
« Last Edit: January 10, 2006, 11:10:23 PM by (unknown) »
Re: How to test RAM chip?
« Reply #1 on: January 10, 2006, 04:41:41 PM »
Are you using this chip to control any Renewable Energy Equipment ?
« Last Edit: January 10, 2006, 04:41:41 PM by (unknown) »
iFred
« Reply #2 on: January 10, 2006, 05:40:08 PM »
on rom, You would have to verify data through each address. The easy way to do this is find someone with a rom chip reader, they can then do a verify to see if the chip is good, then can also dump any data to a file, then erase it and then reprogram it, if it reprograms, verifies and erases then it's most likely good. The ram chip can only be checked on a per address versus data method that I know of. If data or address is faulty then it will null or crash.  All methods are mostly out of circuit. In circuit tests are difficult unless you know what your doing. Replace the ram and forget about it. Rom has specific data, thus more difficult since it contains software, this contact manufacture for another preprogramed chip. Good Luck
« Last Edit: January 10, 2006, 05:40:08 PM by (unknown) »
sian
« Reply #3 on: January 10, 2006, 06:16:03 PM »
yep.. its for tidal power.. though the control side needs SERIOUS work!
S.
« Last Edit: January 10, 2006, 06:16:03 PM by (unknown) »
