Author Topic: DIY Inverter  (Read 1290 times)
The Crazy Noob
DIY Inverter
« on: January 22, 2006, 12:58:15 PM »
I would like to know if anyone has a link to good, free plans for a low-cost DIY inverter. The output-voltage should be 230V~. The input may be in the range of 12-36V. It doesn't have to make a nice sine wave. (I've got some broken TVs and computer-PSUs that I can use parts of.)
Thanks,
The Crazy Noob.
(btw: this is the second time I try to post this, hope it works now)
« Last Edit: January 22, 2006, 12:58:15 PM by (unknown) »
Re: DIY Inverter
« Reply #1 on: January 22, 2006, 07:41:52 AM »
  TCN:It worked the second time probably because
you did something right?
  There have been plans posted and on a Google
search you'll find how to make an inverter from
microwaves.
  Hope this helps.....
   Let me get this all in focus...you want something cheap...pronounced Free...easy to make
readily available...just change a couple of wires around and presto! You have an inverter!
   Ain't going to happen....LOL
   I'm just joshing with you ...
but seriously you can make a fairly hefty
inverter from a microwave if you have enough
time and ambition.
   They had inverters back in the 50's that
changed 12volts to 110vac ...and that was before
transistors...they had a buzzer that hummed at
60 cycles between a dual set of points making it
alternate.....actually on car radios because
part of the radio tubes needed higher than 12
volts to operate ...somewhere around that time
and just before transistors they did come out
with radio tubes that worked on 12 volts.
                   ( :>)Norm
« Last Edit: January 22, 2006, 07:41:52 AM by (unknown) »
