Author Topic: fisher paykel success on electric trike  (Read 3528 times)
solarbbq
« on: September 08, 2004, 11:23:47 PM »
Hi all,
long time no post,
have now got fisher paykel motor working off 24volt on purpose built trike,
yee haa, not particularly efficient though as each phase fires separately,
anyway it means that it is possible to use the volvo type wind gennis as motors too.
You would need to use some hall effect sensors to fire 3 mosfets in sequence to
run the genni as motor.
would be a bit of a challenge would imagine hardest part will be to put hall effect
sensors in correct positions, may not be that hard,
dont intend to try it in near future but maybe down the track a bit
will put some pics on my website of fp motor on trike in coming weeks/months/?????
well sometime
brett
« Last Edit: September 08, 2004, 11:23:47 PM by (unknown) »
commanda
Re: fisher paykel success on electric trike
« Reply #1 on: September 09, 2004, 03:22:37 AM »
10 points for lateral thinking. I want to see your controller/drive circuit.
« Last Edit: September 09, 2004, 03:22:37 AM by (unknown) »
gizmo
    • The Back Shed
« Reply #2 on: September 09, 2004, 08:11:19 PM »
We used a F&P motor to drive a solar car a couple of years ago. We rewound it to suit the lower voltage, used neo magnets and direct drive. It did work ok, heaps of power, but we had too many problems with blown mosfets in the controller, so changed to a differnet drive configuration a few months before the solar race. There are photos, I've put a link from my web site to the solar car's own web site, no longer active but still viewable.
http://www.thebackshed.com
Gizmo.
« Last Edit: September 09, 2004, 08:11:19 PM by (unknown) »
domwild
« Reply #3 on: September 09, 2004, 08:47:40 PM »
The Smartdrive already has three Hall effect sensors on the stator where there is an arrow on your stator. It seems to contain a grey chip (or coil??), one tiny chip marked "S132" and one tiny chip marked "221".  The electronic circuit board on the washing machine contains the word "Hall" on the PCB. As I ripped the washer apart I came across those parts. I have wondered what those chips do and if I can make use of it to pick up the RPM for the LM2917 frequency to voltage converter or if I pick it up from the secondary off the transformer and I meant to ask this forum what those chips are doing.
Dominic
« Last Edit: September 09, 2004, 08:47:40 PM by (unknown) »
elvin1949
« Reply #4 on: September 10, 2004, 12:56:45 PM »
ME TO
elvin
« Last Edit: September 10, 2004, 12:56:45 PM by (unknown) »
RatOmeter
« Reply #5 on: September 10, 2004, 02:54:28 PM »
Well, the "Hall" would be a Hall-effect sensor to sense the speed/position of the rotor.  Output is 99% likely to be a 0 to 5 VDC square wave.  Nicely interfacible to a microcontroller or a V to F converter.
« Last Edit: September 10, 2004, 02:54:28 PM by (unknown) »
solarbbq
« Reply #6 on: September 11, 2004, 05:12:26 PM »
hi again,
i will put up a circuit schematic on my website for those interested,
not sure when i will get chance, in next few weeks probably.
www.users.bigpond.com/solarbbq   (site under reconstruction at the mo)
qizmo had a look at your solar car , wholly toledo very nice.
did you manage to get fisher/paykel running on 3 phase simultaneously or one phase at a time as i have it running.
would really like to discuss with you, found probs blowing mosfets too, but if i keep amps under 10amp on one phase theres no prob. with blowing fets.
« Last Edit: September 11, 2004, 05:12:26 PM by (unknown) »
kurt
    • website
« Reply #7 on: September 11, 2004, 11:10:05 PM »
brett good to see your still about. drop into the #otherpower irc sometime if you get a chance we miss ya.
« Last Edit: September 11, 2004, 11:10:05 PM by (unknown) »
eureka
« Reply #8 on: December 22, 2004, 10:16:48 PM »
Brett,
Had a look on your solarbbq site but could not find the trike info.
There is info about a hub motor 4 wheel drive go-kart using the F&P smart drive motors here http://www.numurkahsc.vic.edu.au/Tech.htm  It's ahybrid and they also had an article in issue 87 of ReNew magazine about their petrol driven battery charger for it.
« Last Edit: December 22, 2004, 10:16:48 PM by (unknown) »
