Hello,
I am a totally new in Electrical field. I have some queries regarding voltage ratings mentioned on name plate of electric motors as below,
1. In some motors voltage rating is mentioned as 1ph, 220-240V 50hz OR
1ph 208-230V 60hz. Now in this case if I want to measure RPM of motor, at what Voltage I should measure it?
2. Some motors are suitable for both 50 & 60hz supply. ( Fractional HP motors used in air conditioners) In this case the voltage rating is 1 ph 208-230V 50/60HZ.
Now in such motors at what voltage RPM should be measured? It should be different for 50hz & 60hz supply?
3. In some multi speed fractional HP motors it is observed that RPM is less in 60hz comparative to 50hz supply. However theoretically it should be more in 60hz.
Pl.explain.
Regards,
Prasanna
