Author Topic: RPM is not enough  (Read 1110 times)
jare
RPM is not enough
« on: July 14, 2004, 04:23:38 PM »
Hi: I have this car alternator (CS144 140Amp) running with this 3000 rpm motor using same size pulley on both and belt. I don't have an amperimeter yet, but the voltimeter said the output is just 2v. Some says that it just need about 1500rpm to start working (are they right?).
Do I need more rpm?
What is the average rpm for a car alternator?
Thanks in advance
JARE
« Last Edit: July 14, 2004, 04:23:38 PM by (unknown) »
johnlm
Re: RPM is not enough
« Reply #1 on: July 14, 2004, 04:46:01 PM »
If the motor is running at 3000 rpm and you have the same size pullys on both the motor and the alternator then the alternator is running at 3000 rpm - plenty fast.  It sounds as if you do not have the field connected up to a 12 v source (battery or battery charger or whatever).  Most car alternators in their stock condition will put out 12V around 700-800 rpm with the field running with a continuous 12v input.  Car alternators will not generate an output without the electromagnetic field activated (which usually consumes 20-30 watts) that is why people who want to use car alternators for windchargers usually convert the armature (field) to permanent magnets and usually rewind them (with more turns of a somewhat smaller wire guage) to get the 12V output at a lower rpm than 700 or so.
« Last Edit: July 14, 2004, 04:46:01 PM by (unknown) »
jare
« Reply #2 on: July 14, 2004, 09:20:27 PM »
Thanks Johnlm
Do you know where I can find how to convert it to permanent magnets and rewind them.
Is that simple and cheap or complicated and expensive?
Another thing, the alternator also have this plug with two wires( red and white) what I supose to do with them?
Pardon my ignorance :/
Thanks a lot
Jare
« Last Edit: July 14, 2004, 09:20:27 PM by (unknown) »
« Reply #3 on: July 15, 2004, 02:02:13 AM »
on my alt you wire those two wires togeather--then hook them up to the positive
lug on the alt .you can hook up a on and off switch if you want..turns the field on
and off [ the big electric mag inside the alt.]
for battery hook up--the neg. goes to the grd. on alt --plus goes to batt. lug on alt..   just do it........
« Last Edit: July 15, 2004, 02:02:13 AM by (unknown) »
« Reply #4 on: July 15, 2004, 02:03:40 AM »
heres mine
« Last Edit: July 15, 2004, 02:03:40 AM by (unknown) »
johnlm
« Reply #5 on: July 16, 2004, 07:37:10 PM »
« Last Edit: July 16, 2004, 07:37:10 PM by (unknown) »
