Author Topic: Connecting 12v to 24v charger/converter, Help  (Read 1168 times)
jare
« on: January 21, 2005, 06:52:26 PM »
Hi:
I recently buy a 12v to 24v charger/converter to use in a emergency, charging my 24v battery bank with my car alternator (50 amp iddle) , but it's not clear to me because in the instruction diagram they use two 12v batt in serial to explain the conection, because my batt bank is diferent I need some advice from you guys.
Thans in advance
Jare
« Last Edit: January 21, 2005, 06:52:26 PM by (unknown) »
drdongle
Re: Connecting 12v to 24v charger/converter, Help
« Reply #1 on: January 21, 2005, 07:36:28 PM »
Scan the original manufacturers diagram and post it, then we can make recommendations.
« Last Edit: January 21, 2005, 07:36:28 PM by (unknown) »
(unknown)
« Reply #2 on: January 22, 2005, 01:36:37 AM »
connect the 12 v from yr vehicle to gnd and 12 as marked in the plate then 24volts to source to be charged.
regards,
seema
« Last Edit: January 22, 2005, 01:36:37 AM by (unknown) »
  • Moderator
« Reply #3 on: January 22, 2005, 06:46:46 PM »
What is the 'STA'?
« Last Edit: January 22, 2005, 06:46:46 PM by (unknown) »
