Author Topic: Controlling My potato battery Output  (Read 3393 times)
Ben Jammin
« on: February 06, 2005, 09:24:00 PM »
How do I get more power from this device?
It is a potato with an iron nail and a copper nail shoved in it. I can't even light an LED with it.
Thanks.
Ben
« Last Edit: February 06, 2005, 09:24:00 PM by (unknown) »
johnlm
Re: Controlling My potato battery Output
« Reply #1 on: February 06, 2005, 02:35:57 PM »
I guess thats why you dont see taters or lemons or whatever in flashlights.
More seriously, I think making batterys out of such things as potatoes, or lemons or dime and penny stacks with lemon juice soaked paper between the coins are more to demonstrate how common items can produce SMALL amounts of electricity.  They will not produce much usefull power, unless I suppose if you used a whole field of taters.  Just had to make a little humor there.
Johnlm
« Last Edit: February 06, 2005, 02:35:57 PM by (unknown) »
kurt
    • website
« Reply #2 on: February 06, 2005, 02:59:41 PM »
i run my computer off of one potato.
it is a very special potato though. It is an Idaho russet grown in Ethiopian epaulated fruit bat guano. no other combination of potato and growing medium has been found to achieve the anywheres close to the same power output.
« Last Edit: February 06, 2005, 02:59:41 PM by (unknown) »
« Reply #3 on: February 06, 2005, 03:00:19 PM »
If you put salt on your potato to lower its resistance and put 4 in series you may light a LED.
« Last Edit: February 06, 2005, 03:00:19 PM by (unknown) »
drdongle
« Reply #4 on: February 06, 2005, 03:18:04 PM »
ROTFL
« Last Edit: February 06, 2005, 03:18:04 PM by (unknown) »
johnlm
« Reply #5 on: February 06, 2005, 07:19:57 PM »
Does it have to be Etheopian bat guano?  Will guano from Carlsbad caverns work ok?
I once saw a (used)car powered by a lemon.  I didnt exactly see the engine but when I asked about it the guy said it was a lemon.
this is going down hill real fast.
« Last Edit: February 06, 2005, 07:19:57 PM by (unknown) »
fishfarm
« Reply #6 on: February 07, 2005, 06:37:15 AM »
That's one hot potato.
« Last Edit: February 07, 2005, 06:37:15 AM by (unknown) »
stop4stuff
« Reply #7 on: February 08, 2005, 01:22:22 AM »
transportable sound system using 500lbs of potatoes!!!
http://latteier.com/potato/
« Last Edit: February 08, 2005, 01:22:22 AM by (unknown) »
« Reply #8 on: February 09, 2005, 08:06:52 PM »
Better be fusing those potatoes
If your potatoes get up against each other and short out
it could explode . . .
« Last Edit: February 09, 2005, 08:06:52 PM by (unknown) »
  • Moderator
« Reply #9 on: February 10, 2005, 12:16:27 PM »
I tried the old glass of saltwater and nails to show my daughter.
Kept adding and adding glasses of water. Never got a high efficiency red LED to light. Ran out of glasses.  Showed her the electricity with a meter. What a flop.
« Last Edit: February 10, 2005, 12:16:27 PM by (unknown) »
Nando
« Reply #10 on: February 12, 2005, 10:01:57 AM »
Ben:
After the laughter, realities. the voltage generated is around 0.3 to 0.4 volts at few microamps, you will need several in series to read greater than 2 volts but not enough energy for LED lighting.
make several batteries from one potato if you cut the potato in pieces to isolate the "batteries" common electrolyte -- you can make batteries using orange, apples, lemons, any acidic fruit.
As well using disimilar metals
Regards
Nando
« Last Edit: February 12, 2005, 10:01:57 AM by (unknown) »
