Author Topic: 12 volt 24volt switching  (Read 1192 times)
(unknown)
« on: November 14, 2005, 10:16:11 AM »
hi can anyone please help
Iknow this is not really about this site but I am really desperate and I think most of you would know how to do this
I am trying to fix an electrical scooter for a friend
basically it consist of two 12 volt car batteries a switch to change from 12 volts to 24 ( to change speed) and another switch to reverse the polarity ( forward and reverse)
then it goes into a dc motor which turns the wheel
someone pulled out the wires
I know the switches, batteries and dc motor work but I cannot wire it up properly
can anyone please help me?
thanks robin
« Last Edit: November 14, 2005, 10:16:11 AM by (unknown) »
Nando
Re: 12 volt 24volt switching
« Reply #1 on: November 14, 2005, 06:47:54 AM »
HERE You have the circuit
The setting is 24 volts and forward ( + voltage up)
Nando
« Last Edit: November 14, 2005, 06:47:54 AM by (unknown) »
Nando
« Reply #2 on: November 14, 2005, 06:52:44 AM »
REPEATING THE DRAWING to solve display errors
Nando
« Last Edit: November 14, 2005, 06:52:44 AM by (unknown) »
« Reply #3 on: November 14, 2005, 07:50:35 AM »
Nando
I had a similar problem sending a circuit diagram with right angled lines as a gif.
I rotated the original about 2 degrees with a photo processor and then converted to gif and it worked ok.
not sure if you are using gif format.
« Last Edit: November 14, 2005, 07:50:35 AM by (unknown) »
stop4stuff
« Reply #4 on: November 14, 2005, 09:10:40 AM »
Fixed the image Nando
yours is displayed as 692x414 pixels, & originally is 865x 518, so the compression looses the quality... I converted your image to RGB (jpg) & resized it to 450x269
paul
« Last Edit: November 14, 2005, 09:10:40 AM by (unknown) »
(unknown)
« Reply #5 on: November 14, 2005, 01:49:53 PM »
cool thanks guys I'm just out of bed so I'll hook it up in a little while
will let you know how I get on
robin
« Last Edit: November 14, 2005, 01:49:53 PM by (unknown) »
(unknown)
« Reply #6 on: November 15, 2005, 03:51:10 AM »
thanks a million  hooked it up and worked a treat
if only i had asked a few days ago
THANKYOU VERY MUCH
robin
« Last Edit: November 15, 2005, 03:51:10 AM by (unknown) »
