Author Topic: Wind speed indicator  (Read 1179 times)
Shadow
« on: April 22, 2006, 02:16:05 PM »
 I recently got a Walmart 'weather station' I mainly want to use it for the wind speed indicator.It comes with a wall wart that reads 6 volt dc 100ma output. Question, Does that mean the main unit only draws 100 ma? or thats the total output of the transformer? I'm wondering if I can hook the unit direct to my 6volt 400amp hour deep cycle battery?Will it only draw what it needs? or is that like jump starting a vehicle with 400 amps?
« Last Edit: April 22, 2006, 02:16:05 PM by (unknown) »
wpowokal
Re: Wind speed indicator
« Reply #1 on: April 22, 2006, 08:27:04 AM »
100 ma is transformer output, your unit will draw something less than that, IMHO, hook it to your 6v bateries.
allan down under
« Last Edit: April 22, 2006, 08:27:04 AM by (unknown) »
« Reply #2 on: April 22, 2006, 08:38:46 AM »
How much did it cost?What other gizmos does it have?
« Last Edit: April 22, 2006, 08:38:46 AM by (unknown) »
« Reply #3 on: April 22, 2006, 08:51:45 AM »
The 100ma should be the rated output of the wall wart.  Your 6V battery bank voltage will change, but if it is within the tolerances of the device, it should work.  If not you could rig a circuit with a voltage regulator, either an adjustable one, or a 7805 voltage regulator with a diode between the middle leg and ground to raise the voltage by the equivelant of the diode voltage drop which should put you into a workable range.  If I recall correctly the case of a 7805 regulator in most packages is usually tied to that leg, so don't ground it or you'll just get 5 volts out of it.  Rig a piece of aluminum to the case to cool the regulator so that it won't over heat, although at less than 100 ma that shouldn't be a problem for the common t220 variety.
On the right side of the breadboard I was playing around with a 7805 regulator and rigged a couple of diodes across and I think it put out something like 6.2 volts or so.  The left pin is tied to the source, the middle pin is connected across the two diodes in series so that the will conduct to ground, and the third pin is the output to the device you want to power.  In the case above a couple of white LED's are hooked in series.  (LED's are better regulated by controlling the current the above was just a test of output voltage of the regulator)  Rich
« Last Edit: April 22, 2006, 08:51:45 AM by (unknown) »
