Author Topic: C35 functions question  (Read 2931 times)
ZooT
« on: July 31, 2006, 06:46:42 PM »
I have a xantrex C35 here and upon reading both the instructions included and this board am confused as to whether I should configure it as a diversion controller or as a load dump controller.
If possible I'd like to connect both an ametek 30 based wind generator and one of those cheapo 45 watt harbor freight PV arrays to it.
Is this out of the question?
If I'm not supplying enough information let me know and I'll try to add whatever's needed to fill in any blanks.
« Last Edit: July 31, 2006, 06:46:42 PM by (unknown) »
Nando
Re: C35 functions question
« Reply #1 on: July 31, 2006, 02:25:58 PM »
BLANKS:
Voltage output of panel
Voltage output range of wind mill
Current of both items
Nando
« Last Edit: July 31, 2006, 02:25:58 PM by (unknown) »
SamoaPower
« Reply #2 on: July 31, 2006, 04:30:04 PM »
I think you have a little confusion with your C35 mode terminology. The third mode is as a load controller or undervoltage lock out.
The best way to connect it for multiple sources is as a diversion controller which requires a dump load. Connect your Ametek (through a diode) and the PV directly to the battery and connect the C35 as a diversion controller.
Works fine, do it myself with a C40.
« Last Edit: July 31, 2006, 04:30:04 PM by (unknown) »
« Reply #3 on: July 31, 2006, 06:20:52 PM »
I would run the C-35 as a Diversion, or dump load controller.  I would not run the C-35 as a charge controller with a highly rippled DC source such as your Ametek 30V motor.  It would play havoc on the 3 stage charging alogrithms I would suspect.    Ideally you would rig a dump load such as a resistance heater, or water heating elements, such that it does not exceed the rating of your controller when functioning as a diversion load controller (this may be different than the rating in charge control mode, so read your manual), but ideally consumes more than the maximum sustained generation you will see.  Do not use light bulbs, as if they burn out, they become open circuit, and you will have no load to keep the voltage down.  Since you are running an Ametek 30V, I presume you have a system voltage of 12V.  I don't think that even under a sunny wind storm you would likely exceed 30 amps, so if your controller can handle it, rigging a dump load that draws about 30 amps, or 360 watts at 12V would be sufficient - read your manual to see the maximum amps that your system can switch, and ensure that I=V/R  where I is the amps, V is the system voltage, and R is the resistance of your dump load - that the value for the resistance of your dump load is large enough that the value of I, for the largest value of V that your system will see which is the voltage that you switch on the dump load at, is less than the maximum amps that your load controller can switch.
Here is a photo of the guts of a C-40 that I have rigged up as a diversion load controller for a C-40.
For the C40, you simply set the jumpers on the right side of the board in the photo, set the LVR jumper to 'Auto',  the mode jumper to 'load control', then select the jumper for the appropriate voltage.  Once you have done that, you adjust the variable resistors, which are the two blue wheels near the center, for the voltages that you want the load turned on at and off at.  You turn the diversion load off at a voltage far enough below the voltage that the diversion load is turned on at so that the system will not cycle too rapidly. Then you can connect the controller to the batteries and the load.  Those voltage controls aren't real accurate, so you should probably get a meter, and test the voltages to make sure they are what you want for your batteries.  Obviously use a wire size that can handle the amps, at least 10 guage for 30 amps.  I also always use a fuse right off of the positive post of the battery, just in case the insulation were to get cut, or some other problem developed with the wiring.  Since I am under 30 amps, I use a 30 amp auto type fuse in an inline holder.
Again, for your C35, and maybe even for different models of the C40 it may be different, so read your manual.
hope this helps a little, Rich
« Last Edit: July 31, 2006, 06:20:52 PM by (unknown) »
ZooT
« Reply #4 on: August 01, 2006, 12:06:26 AM »
Rich,
Yeah I thought the diversion controller was the way to go, yet I'm new to this stuff and wanted to make sure before I cooked something.
Everyone mentions dump loads and dump load controllers here so I thought maybe I was missing something.
That C40 looks just like my C35 with the exception of the much larger power transistors(?) and the heat sink.
I see you opted for the outboard readout, I didn't get that but did get the temp precomp sensor.......
Nando,
17.2 VDC open
Current output
3000mA max
Advertised wattage
45
Ametek 30VDC
080987K7 Data Provided by Brandy Nelson of solarwellpumps.com
rpm's      Open Volts   Shorted Amps
  1.        18.5V        5.3 Amps
  2.        20.0V        5.7 Amps
  3.        23.4V        6.5 Amps
  4.        26.9V        7.2 Amps
  5.        30.0V        8.0 Amps
  6.       33.5V        8.7 Amps
Is that enough to get you going?
« Last Edit: August 01, 2006, 12:06:26 AM by (unknown) »
« Reply #5 on: August 01, 2006, 04:14:15 AM »
Tom from New Hampshire did an evaluation of the temperature compensator, and I took a couple of resistance readings for him from one that I have at another location.  He found it functioned the equivelant to a specific value thermistor.  I don't recall the specific value off hand but I have it written down somewhere, and of course his post on it is archived on this site.  That C40 in the photo is hooked up as a diversion load controller, so I didn't consider it quite as critical for that one.  Rich
« Last Edit: August 01, 2006, 04:14:15 AM by (unknown) »
