Author Topic: Sun Tracker  (Read 1539 times)
David HK
  • Country: hk
Sun Tracker
« on: March 13, 2007, 08:28:05 AM »
For nearly two years I have been trolling around the Internet looking for a Sun tracker circuit that may be worth following. I have also looked at many circuit books and never come up with anything that is precisely what I want.
I think I have found it at last and it was designed by Richard Gideon and can be found at http://www.phoenixnavigation.com/ptbc/home.htm
The article containing the circuit and explanation was posted in April 2005.
After looking at the circuit layout I asked a few questions in the Forum area.
I decided to go ahead and build it and quite early on I realised that so many capacitors and resistors would be a nightmare to wire up on a small board. I decided to do something that I have never done before which is to make up my own two sided printed circuit board after down loading software from PCB Express - http://www.expresspcb.com/
PCB Express offers a special deal for three printed circuit boards if one can fit the entire circuit on a board of their size. This I managed to do and after fiddling a bit I suddenly realised how wonderful a two sided board was for jumping connector lines up and down. I sent off the order on a Thursday and the three boards were in my hands the following Tuesday afternoon.
Whilst the boards were being manufactured I went shopping for all the parts plus sundry items such as weatherproof boxes, relays switches and so on. Time was on my side and I made up most of the 12 volt hardware side before the printed circuit boards arrived.  In addition to the control circuits there are two other important items namely; the actuator and the light sensor.
The actuator is a Superjack 18 inch model with a 36 volt DC motor. I shall be running it on 12 volts DC so the slow drive is perfect. I checked the cam follower switches and found they were Normally Closed and my circuit required Normally Open types. I found some excellent replacements in an electrical shop which offers Japanese made models and include both Normally Open and Closed contacts, so this was a bonus. The dimensions of the new switch exactlty matched the old so the changeover was very simple.
The light sensor consists of two Light Dependant Resistors (LDR) in a weatherproof housing. On the outside I have glued on a shadow maker so that the movement of the sun causes a shadow over one of the LDR's. It's the same as a sundial. To make the LDR's more sensitive I have covered them with 15mm copper pipe pots with a peephole in the top.
The new boards arrived and I populated them in the usual way to ensure component values were in the right place. The centre of the electronics is based on a LM 339 chip - a comparator.
All the interfacing wires were connected and then the final moment came to connect up to a 12 volt battery. This was done and I am pleased to report that there was no magic smoke. The weather on the day of testing was rather heavy cloud with just the odd moment when the sun shone through. At the right moment I tweaked one of the variable resistors and lo and behold the system came to life and continued to track on and off throughout the day until the sun disappeared leaving the usual darkness effect. At a moment in time the system suddenly came to life again and the electronics returned the unit to face East ready for start up next day.
Needless to say I was quite pleased with all of my efforts, especially my first-time-ever with a double sided printed circuit board. I dare say some of you readers could make a better job of the layout and reduce its size, but I like having space to work in.
There are one or two interesting things about the circuit which have not been given an explanation in the circuit briefing written by the designer. Firstly, the printed circuit board operates on 9 volts from a 78L09 regulator while the rest of my board and the relays currently work from a 12 volt DC supply. If I was to change over to a 24 volt system the only items I need to change are the relays.
After the dish has `parked' in the East at night both LED 1 and 2 remain lighted and will do so until light appears the following morning when they extinguish themselves. The circuit design makes provision for an `optional' power supply switch so that the LED's could be turned off rather than being left to glow all night. At least that's my guess. As far as I can see the LED's remain lit due to the Light Dependent Resistors being saturated with `darkness'. I dare say some of the very experienced electronic experts on this site will better understand this better than I and come up with an idea to turn them off overnight - other than the optional switch that is. Despite remaining `on' however, no harm appears to have been done to the circuit.
The circuit also contains a delay in the form of a 3,300uF electrolytic capacitor which takes about four minutes to charge up. This absence of this feature would mean that the circuit was constantly motoring to follow the sun.
The light sensor module is interesting. I fitted it on top of the test bracket expecting everything to point directly at the sun, but it does not. I realised that this is due to the way in which the Light Dependant Resistors are set up in the module. The answer to correct alignment to the sun is to perform a trick with the mechanical part and adjust one against the other so that both are satisfied. The light sensor does its work and the metalwork points at the sun. This bit of fine tuning requires some fiddling between the azimuth and elevation of the sensor on the solar mounting, and the variable resistor controlling the sensitivity of the light dependant resistors. I have yet to master this, but it should not be a problem.
To help with this setting up process the main board also contains a toggle switch which takes 9 volts from the printed circuit board through a 4.7K resistor to the centre pin. The remaining two contacts on the switch are then wired to the base of each TIP 120 so that the actuator can be motored to the East or West. This is very useful for setting up.
Just to remind everyone this is a SUN tracker not a solar tracker. Allowing for the gradual change of the earth in relation to the sun in the next few months I am hoping to have my solar panels exposed to the sun for about eight hours each day.
So there we are, two years of my patience and a very good circuit. I hope you all like the article. Cost wise it has probably hinged around US$60 or less, but the future benefits outweigh the capital cost. I can now invest in some serious solar panels (I do things in reverse if I can - work out the control equipment then buy the parts).
If you want copies of my PCB Express files you will need to download the software and then ask me to mail them to you.
Next job on the list is to purchase some deep cycle batteries, but I am at least getting closer to opting for a 24 volt DC system in my home. More decisions!
David HK
« Last Edit: March 13, 2007, 08:28:05 AM by (unknown) »
Re: Sun Tracker
« Reply #1 on: March 13, 2007, 01:40:20 AM »
It took me a while to find the correct article in that website; here's the direct link:
http://www.phoenixnavigation.com/ptbc/articles/ptbc55.htm
One question though; I assume you are familiar with the RedRok tracker. I'm curious as to why this wouldn't fit your needs. I am contemplating building the RedRok, but will look into this design as well.
Also, I'm curious as to the reason for using relays, as MOSFETs seem more reliable to me in the long run (no contact burn).
I'll study this design a little closer later. It looks very nicely built though, built to stand years in the outdoors. My compliments. Such craftmanship is a joy to look at.
« Last Edit: March 13, 2007, 01:40:20 AM by (unknown) »
David HK
  • Country: hk
Re: Sun Tracker
« Reply #2 on: March 13, 2007, 01:50:48 AM »
Peter,
Thank you for the comments. I am 58 years old and a mere novice at electronics. I will build something if I understand the circuit and it appears reasonably simple.
I expect you are much more expert at these things so if I knew what Mosfets to use I would try them.
Remember this is a prototype and I have two more circuit boards to play with.
I'm trying hard to keep up! At least it works, so I am very happy.
David HK
« Last Edit: March 13, 2007, 01:50:48 AM by (unknown) »
David HK
  • Country: hk
Re: Sun Tracker
« Reply #3 on: March 13, 2007, 04:50:18 AM »
After refreshing my memory on the Red Rok site I recall I gave up because there were so many choices and numerous components which made it all too complex. I wanted something simple, easy to build and reliable. I am now fairly sure I have achieved this.
My original script contains a reference to an eletrolytic capacitor of 3,300uF. This is incorrect and should read 1,000uF.
After a trip to Hong Kong international airport and back I have just returned home and found my sun tracker unit parked facing East, ready for sunrise tomorrow. This is great stuff - automation and its benefits.
Regards,
David HK
« Last Edit: March 13, 2007, 04:50:18 AM by (unknown) »
Re: Sun Tracker
« Reply #4 on: March 13, 2007, 07:15:04 AM »
David;
  I like the layout, nice clean easy to work with.
That webiste is one that I've spent hours lurking on as well, lots of good info on the Tesla stuff too.
Great work!!
Have you already begun to notice any added power after installing?
« Last Edit: March 13, 2007, 07:15:04 AM by (unknown) »
rossw
Re: Sun Tracker
« Reply #5 on: March 13, 2007, 09:26:07 PM »
Just to add "grist to the mill" as it were, I purchased a commercial tracker a while ago, which included a commercial control unit. It's been nothing but trouble, blowing up about once every couple of months.
The last time it wasn't repairable, too much was fried.
I looked at the redroc one, and amongst its other failings (IMO) is that it is simply not practical to use in a 48V system (such as mine).
To this end, I've designed and am in the process of building my own controller.
It uses a fraction of the parts of either controllers mentioned here, and should (I hope) prove to be very reliable.
In answer to one of the other questions raised in another message, I plan to use a single relay for reversing the motor, and a single FET for control. Why? Because it is a simple, and I believe fairly reliable solution. Using 4 FETs in an H-bridge has some elegance to it, but drive/bias for the high-side FETs in a high-voltage application adds a lot of extra complexity, cost and failure-points. A relay should be quite reliable, except as was raised - burning (or welding, arcing) of contacts. I've addressed that I think, quite elegantly - by turning OFF the FET before operating the relay, so the relay is never switching current, it should last a long time.
If there is interest, when I get mine working and proven, I'll post details.
« Last Edit: March 13, 2007, 09:26:07 PM by (unknown) »
David HK
  • Country: hk
Re: Sun Tracker
« Reply #6 on: March 13, 2007, 09:49:38 PM »
I have decided to redesign the light sensor module. Rightly or wrongly I have the impression that when the module is at a certain angle the transluscent cover on the box top allows light through at an angle to the sensor (Light dependent Resistor) that should be in the shade.
My new module will have two water resistant boxes (same size as the existing) with a piece of black plastic glued between both. This will guarantee no extraneous light interference. I shall also raise the height of the shadow maker from the current 5 inches above the box lid to about 7 inches. If its too high I can reduce this later.
I will post a new picture in a few days.
My thanks to all contributors so far - very interesting comments.
David HK
« Last Edit: March 13, 2007, 09:49:38 PM by (unknown) »
hydrosun
Re: Sun Tracker
« Reply #7 on: March 16, 2007, 11:00:25 PM »
I've used the Redrok tracker in  three systems. I ask  Duane to custom fit the system for an additional 5 bucks. So I got  one that can handle a 48 volt system and have a 90 second delay in movement.  It took me  some fiddling to get things set up corectly. At first it went to the west at night because I had it upside down.  On another system I blew out one circuit because a sticking used linear motor unit.  My own unit has 1200 watts of panels and has been working well for more than three years. I've homebrewed a simple tracker for a solar cooker platform so I know how hard it is to make a reliable circuit that  does  it well. I've been pleased with the small sized surface mount circuit that fits in a jar to protect it from moisture. I can't beat the $42 price either.  I am impressed with your  own circuit, but it reminds me of all I learned making my own hydro units, until I found how much better  a Harris hydro is for reliabilty and efficiency.
Chris
« Last Edit: March 16, 2007, 11:00:25 PM by (unknown) »
