You are right, I first went to a supplier I used before MCM electronics but they don't list many diodes like I have in stock. A more general Google search found this. Note these are all higher voltage than we want with lower amperage rating (less than an ampere.)
http://www.amiparts.com/partslist/hvdiode.htm
Microwave oven diodes
AA-1140 Female Terminals, Wire Gauge: 22-18, Tab Size: .250 Go to Section
AMCT-1 Non Insulated Terminals, Male Terminal, Wire Gauge: 22-18, Tab Size: .250, Qty Per Pack: 50 Go to Section
AMI2066 High Voltage Diode - 1/4" FM quick connect on cathode lead, 3/16" FM quick connect on ground lead. Overall length 3 1/4". 12KV 350MA, Replaces: Popular in Tappan Home Microwave Ovens. Direct Replacement for Tappan Part # 5303091303 and more Go to Section
AMI3347 HV Diode - Will replace any commercial or home microwave oven diode with 2 leads. 16KV, 750MA Go to Section
AMI3D71 HV Diode - 12KV 350MA, will replace any home unit with 2 leads. Go to Section
AMI9509 High Voltage Diode - 3/16" quick connect on cathode lead, round grommet on ground lead. Overall length 3 1/4". 12KV 350MA, Go to Section
AMI9510 High Voltage Diode - 1/4" male spade on cathode lead, round grommet on ground lead. Overall lenght 3 1/4". 12KV 350MA, Replaces: Popular in Amana, Whirlpool and other home ovens.Replaces Amana R0156595 Go to Section
AMI9511 High Voltage Diode - 1/4" FM quick connect on cathode lead, ring terminal on ground. Overall length 8 1/2".12KV 3 50 MA, Replaces: Popular in many Sharp microwave ovens Go to Section
AMI9512 High Voltage Diode - 1/4" FM quick connect on both ends. Overall length 3 1/8". 12KV 350MA, Replaces: Popular in Amana, Magic Chef & and other home ovens. Go to Section
AMI9513 High Voltage Diode - 1/4" FM quick connect on cathode with 8" lead wire, with 1/4" FM quick connect. Round grommet on ground lead. 12KV 350MA. Replaces: Popular in Sharp, Replaces Sharp # FH-DZA009WRKO, FH-DZA015WRKO, Tappan Part # 5303212799, FW-QZA040WRKO, Amana Part # R0809505 and more. Go to Section
AMI9514 High Voltage Diode - 1/4" FM quick connect 8" lead wire, with 1/4" FM quick connect on cathode. Extra 6" long wire with ring terminal on ground lead. 12KV 350MA. Replaces: Go to Section
AMIBA10B High Voltage Diode - O.E.M.#BA10B Diode, P.C. Mount, Replaces: Go to Section
BB-1141 Female Terminals, Wire Gauge: 16-14, Tab Size: .250 Go to Section
MCT-1 Non Insulated Terminals, Male Terminal, Wire Gauge: 16-14, Tab Size: .250, Qty Per Pack: 50 Go to Section
MMFA Brass Tab Adapters Tab Size: .250 Go to Section
THV512 HV Diode, 1/4"FM quick connect on cathode lead, round grommet on ground lead. Overall length 3 1/2" 12KV, 350MA Go to Section
2B72757B H.V. Transformer - Fits over 40 models of Frigidaire, Sears, Tappan and Whirlpool microwaves. Go to Section
N685 High Voltage Transformer - PRI. 110V., Fil. 3.0V., OHMS 135, H.V. Secondary 2,130V. (For use in 600 watt or less microwave ovens) 3 1/8" w. x 4 1/2" d. x 3 7/8" h., Mfg. by Magnetek-Triad (#N685-7070)
