Author Topic: controller  (Read 946 times)
windspeed
controller
« on: February 19, 2008, 11:34:53 PM »
would I get away with a tristar 45 controller on my 10 ft 24 v dual rotor if I kept max output at 750 w...is the tristar procted against overload in diversion mode
 and finally would I be able to  ensure furling at 750 w
windspeed
« Last Edit: February 19, 2008, 11:34:53 PM by (unknown) »
kurt
    • website
Re: controller
« Reply #1 on: February 19, 2008, 05:28:19 PM »
watts law says it would be fine amps * volts = watts i would assume the controller is protected from overload in diversion mode by the size of the dump load you choose you need to size it so that at max draw it cannot overload the controller you would use ohms law to calculate that http://www.the12volt.com/ohm/ohmslaw.asp
http://www.keelectric.com/ketools/ohmswatts.html
as far as the furling goes getting furling to work properly is an art onto itself most people make it to the plans then adjust tail weight and pivot angle as needed to get the furl point were it needs to be
« Last Edit: February 19, 2008, 05:28:19 PM by (unknown) »
