Author Topic: XBM Xantrex Battery Monitor questions  (Read 1946 times)
Speo
« on: April 15, 2008, 02:23:39 AM »
Hello guys,
I got an XBM - Xantrex Battery Monitor and I have few questions regarding the wire required to install it.
Xantrex provides an installation kit which I consider too expensive and it is not long enough for my needs. Their cable is shorter than the maximum recommended length.
Here are some facts:
In the installation guide, it is mentioned: "you will need a two-wire twisted pair connection cable (minimum AWG 24) and a three-wire flexible connection cable (minimum AWG 21)"
The 2 wire twisted pair cable is used for current sensing and the 3 wire flexible cable is used for voltage sensing, positive supply voltage and negative supply voltage.
In the connection kit provided by Xantrex, there is one cable with 3 pairs of wires, each pair twisted.
Here is a diagram: http://www.xantrex.com/web/id/1088/docserve.aspx
My questions are:
1) Can I use a 6 twisted connectors cable instead of a cable with 3 twisted pairs?
2) If the first answer is yes, is it better if the 6 twisted connectors cable is shielded?
Thanks,
Speo
« Last Edit: April 15, 2008, 02:23:39 AM by (unknown) »
Nothing40
Re: XBM Xantrex Battery Monitor questions
« Reply #1 on: April 16, 2008, 02:13:47 AM »
Just my two cents..
  1. Sure.
  2. It can't hurt,just ground the shield.
« Last Edit: April 16, 2008, 02:13:47 AM by (unknown) »
Speo
« Reply #2 on: April 16, 2008, 08:52:00 PM »
Thanks, I'll give it a try.
Speo
« Last Edit: April 16, 2008, 08:52:00 PM by (unknown) »
