Author Topic: whats up doc  (Read 1176 times)
windspeed
whats up doc
« on: April 25, 2008, 09:23:03 PM »
has anyone got a link to the doc watson website
windsped
« Last Edit: April 25, 2008, 09:23:03 PM by (unknown) »
KurtJ
Re: whats up doc
« Reply #1 on: April 25, 2008, 04:00:36 PM »
not sure if this will help but its all I got. http://www.powerwerx.com/product.asp?ProdID=34676&CtgID=
Kurt
« Last Edit: April 25, 2008, 04:00:36 PM by (unknown) »
kurt
    • website
Re: whats up doc
« Reply #2 on: April 25, 2008, 05:22:16 PM »
tomw posted the basics of how to wire one up here sounded pretty simple to me.... http://www.fieldlines.com/comments/2008/4/24/201545/178/1#1
« Last Edit: April 25, 2008, 05:22:16 PM by (unknown) »
windspeed
Re: whats up doc
« Reply #3 on: April 26, 2008, 03:49:03 AM »
sorry for that
I checked their website I assume it is fine to connect the doc in series with the plus and minus turbine wires and battery after the rectifier
should that be after the fuse and before the battery disconnect
windspeed
« Last Edit: April 26, 2008, 03:49:03 AM by (unknown) »
DanB
    • otherpower.com
Re: whats up doc
« Reply #4 on: April 26, 2008, 06:39:26 AM »
« Last Edit: April 26, 2008, 06:39:26 AM by (unknown) »
snowcrow
Re: whats up doc
« Reply #5 on: April 27, 2008, 04:22:42 AM »
  Hi windspeed, It would be best not to a fuse between the turbine and batteries!!  If the fuse blows, the turbine will no longer be under load and will over speed!!
Blessings, Snow Crow
« Last Edit: April 27, 2008, 04:22:42 AM by (unknown) »
Re: whats up doc
« Reply #6 on: April 28, 2008, 12:50:24 PM »
The rectifier acts a little bit like a fuse
how do you protect the battery and wiring if there happens to be a short circuit on the Winds Turbine line before the rectifier ?
« Last Edit: April 28, 2008, 12:50:24 PM by (unknown) »
Re: whats up doc
« Reply #7 on: April 28, 2008, 02:09:28 PM »
Woof;
Personally, I just fuse the sources near the battery and fuse for catastrophic failure and not anything low enough to be blown by all sources feeding full current. In my case now that is a 100 amp fuse. My conversion might see 30 or 40 amps but basically never nail that 100 amps. A wrench across + and - will pop the fuse but no incoming will. Just my way.
« Last Edit: April 28, 2008, 02:09:28 PM by (unknown) »
