Author Topic: Wind and Solar Hybrid System Connection Question  (Read 992 times)
(unknown)
« on: September 06, 2008, 04:18:29 AM »
I have a small 20 watt solar panel and a 220 volt small home built wind turbine. This is a small system but I would like to be able to connect these together to charge batteries.  My questions are:
Can I use the same charger? or
Can I connect the panel straight to the batteries and then connect the wind turbine to a charger?
I would like both of these to charge the batteries and want to make this one simple system.  I have reviewed the information online and haven't found the info. Any help would be great.  I have used alot of the info off the message boards and have found all the info to be very helpful.  Now I'm ready to hookup and start charging..........
Thanks,
Rick
« Last Edit: September 06, 2008, 04:18:29 AM by (unknown) »
wpowokal
Re: Wind and Solar Hybrid System
« Reply #1 on: September 05, 2008, 10:44:14 PM »
« Last Edit: September 05, 2008, 10:44:14 PM by (unknown) »
  • Moderator
Re: Wind and Solar Hybrid System Connection
« Reply #2 on: September 06, 2008, 08:15:16 AM »
Can you tell us more about the 220V turbine?
« Last Edit: September 06, 2008, 08:15:16 AM by (unknown) »
