Author Topic: Step Up Converter 3V - 5V circuit needed.  (Read 2939 times)
Junkie
    • Scraptopower.co.uk
« on: November 09, 2008, 07:13:37 PM »
I've been experimenting with Peltiers for a small portable charger. I've got the peltier rigged up in my little portable device powered off a tea light candle. It outputs 3.5V - 4V and will run my radio and a 12V computer fan for cooling slowly. Any ways does anyone know of any  circuits to step up the 3V to 5V so I can charge my mp3 player via usb ? Thanks,
« Last Edit: November 09, 2008, 07:13:37 PM by (unknown) »
Re: Step Up Converter 3V - 5V circuit needed.
« Reply #1 on: November 09, 2008, 12:44:33 PM »
2 Peltier units in series?
« Last Edit: November 09, 2008, 12:44:33 PM by (unknown) »
Junkie
« Reply #2 on: November 09, 2008, 12:52:54 PM »
I am only using one. It will mess up my design if I have to use two peltiers :-)
« Last Edit: November 09, 2008, 12:52:54 PM by (unknown) »
« Reply #3 on: November 09, 2008, 01:43:39 PM »
The device here (87% efficient) will do that.
http://www.maxim-ic.com/quick_view2.cfm?qv_pk=1167
« Last Edit: November 09, 2008, 01:43:39 PM by (unknown) »
jimovonz
« Reply #4 on: November 09, 2008, 01:47:31 PM »
Max1708(2A) or MAX1709(4A): Step-Up DC-DC. 0.7-5.0V input, 5V output
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2307
Free samples available.
« Last Edit: November 09, 2008, 01:47:31 PM by (unknown) »
Junkie
« Reply #5 on: November 10, 2008, 08:04:17 AM »
Thanks for the replies. Ordered that chip, I am going to try and follow the circuits on the data sheet though I'm far from being any good at electronics. Ta,
« Last Edit: November 10, 2008, 08:04:17 AM by (unknown) »
Junkie
« Reply #6 on: November 11, 2008, 08:43:47 AM »
Well, I couldn't get the maxi chip here, but I found a similar thing and a circuit to boot. But I can't get it to work. The only thing I know is wrong is the diode is 1n5817 and not 1n5818 will this make a difference ? I wouldn't have thought so but ya never know.
http://foosel.org/_detail/hacks/cn8-5.png?id=hacks
« Last Edit: November 11, 2008, 08:43:47 AM by (unknown) »
JamesJackson
« Reply #7 on: November 12, 2008, 07:36:35 AM »
It's more likely to be the inductor that's the problem.
If that's not it - then the layout is something to check. Circuits like this can be crirital on component placement. Use the datasheet of the LT1073 as a guideline.
Also, you do not mention which version of the LT1073 you are using. There are 3 versions.
LT1073 - adjustable
LT1073-5
LT1073-12
I would assume (dangerous, I know) that you would want to use the LT1073-5 to get the 5-volts that you are wanting.
Pretty cool idea - and a cool circuit. Let me know how it goes.
Regards,
James Jackson
« Last Edit: November 12, 2008, 07:36:35 AM by (unknown) »
