Author Topic: wind charge controllers  (Read 1140 times)
nocita1
« on: November 10, 2008, 04:27:43 AM »
 Hi gang . I was wondering if a charge controller rated at 30 amps could handle a pma that is designed to go no higher than 15 amps @ 1200 rpms? it reaches 12 volts @ 150 rpm, and the voltage reaches ,1200 rpms. I ask because I have one, and would like to use it, I would like some opinions from those who are more experienced than I Thanks
Moved to Controls since it is about a controller. Be smart to disclose full details like make and model of controller, too, if you want to avoid 20 questions on exactly what you have.
« Last Edit: November 10, 2008, 04:27:43 AM by (unknown) »
nocita1
Re: wind charge controllers
« Reply #1 on: November 09, 2008, 09:30:13 PM »
sorry gang should read reaches 90 volts @1200 rpm
« Last Edit: November 09, 2008, 09:30:13 PM by (unknown) »
  • Moderator
« Reply #2 on: November 09, 2008, 10:27:13 PM »
The "rated at 30 amps" makes me think it is a solar controller.
If so, it will blow up if used with a windmill.
« Last Edit: November 09, 2008, 10:27:13 PM by (unknown) »
nocita1
« Reply #3 on: November 09, 2008, 10:43:28 PM »
yes it is a solar controller how can I get around it .
« Last Edit: November 09, 2008, 10:43:28 PM by (unknown) »
  • Moderator
« Reply #4 on: November 09, 2008, 10:45:39 PM »
You can't.
You need a totally different type of controller.
Dump / diversion / shunt type is kind for windmills.
« Last Edit: November 09, 2008, 10:45:39 PM by (unknown) »
independent
« Reply #5 on: November 09, 2008, 11:37:52 PM »
Use Ghurd's controller. You have to build it--cool.
They are very very reasonably priced. You can get one at ghurd.info
« Last Edit: November 09, 2008, 11:37:52 PM by (unknown) »
