Author Topic: Combining 2 charge controller output?  (Read 40890 times)
wilfor03
  • USA: Union Grove, Alabama
« on: June 01, 2010, 11:26:01 AM »
I got a question for the board at large......I have a Sunforce 30A charge controller and was wondering if I can combine another of the same (with different set of panels) to the same battery bank (12V-3750AH) without blowing anything up?  Right now, just a question...........tommorrow, maybe reality....appreciate the info...........Bill    ???
Bill
Re: Combining 2 charge controller output?
« Reply #1 on: June 01, 2010, 11:42:36 AM »
That is fine.
Just keep the panels on one seperate from the other.
wilfor03
« Reply #2 on: June 01, 2010, 01:12:53 PM »
Appreciate that Mr. ghurd....I was out watching my amps meter this morning (had to use backup again last night) and was thinking about if I could add another charging circuit with no fear of fire 'n stuff.......thankyou......Bill   ;D
Bill
« Reply #3 on: June 01, 2010, 01:19:06 PM »
I've regularly had two or three controllers feeding my small battery in the past, but have kept the panels entirely separate electrically as G says.
BTW, if you were/are using MPPT and your sets of panels have different shading or orientation, then you'd likely get better output by having a separate controller for each string.
tanner0441
« Reply #4 on: June 01, 2010, 01:57:01 PM »
Hi
I have my wind turbine controller output and solar controllers paralleled at the battery fuse, as I meter them separately I have to add the outputs in my head for the charge rate, ie 4A from the solar and 9A from the wind = 13A in total.
As the others say make sure the only common wiring is after the diodes.....
Brian
