This project has been slow.
I was to use a 2 HP 3 Phase motor.
I went with the Ametek 38 volt brushed PM motor that was my wind turbine.
A storm took it out this spring. Broke one of the blades so I did not take
the time to repair and reinstall it. Was nice to watch.
Plus I have a spare.
I have been going down to my dad's a lot this year. He is 81 so I work on his tractor for him.
Work on it a lot more each passing year. I don't know which will go first.
Him or the Farm All A 100. He is trying his best to make it the tractor. He has had it for over 40 years.
While there I helped him clean out the spill ways ( 2 ) to our lake several times.
Lot's of rain and other things. Only one has run off unless it rains hard.
There is still enough water to fill a 6 '' pipe leaving the lake.
As I have said in the past, I plan to use 3'' or 4'' pipe. Maybe 3'' with 2 runs for 2 units.
Water gets to low for 2, Shut one off.
To the lowest point of the dam is about 100 feet run. ( +/- ) I have measured this.
I have not measured the head but it is around 20 to 25 feet. Maybe 30 feet.
This is what I made for my first test.
It does not look like much I know. I will paint it to make it look better.
It will be mounted to lay on it's side to work.
I will make a cover for the Motor to protect it from the elements..
I tested the angle for the best / Fastest rotation with an air hose.
It was the only way I knew of to get a starting point.
With the bolt and some shims I can adjust the angle if needed.
The blade is a plastic blower blade. I have looked at many things and this looks to be promising.
That is without buying something made for it. It is 6 1/2 '' by 3''.
I used the same arbor that was on the wind turbine. The pipe is 1 1/4''.
It is flattened out at the end to make a spout 1/4 by near 3'' wide.
I will go from 3'' or 4'' pipe down to the 1 1/4'' at the very end. I have a lot of ways to try.
Make the 1/4'' spout BIGGER or smaller. Closer or father away.
Bigger pipe spout or smaller.
Different Motors / Gens.
I will post more when I get the thing installed. Installation may take some time.
Like I said this one is SLOW.
Thanks for the help with this project given on and off the board.
