Author Topic: 10'er is up for testing  (Read 1774 times)
97fishmt
« on: July 09, 2010, 07:41:26 PM »
It starts up in the slightest breeze.
And still safe with a smallish tail.
The tower is doing fine and would
like to go larger.
« Last Edit: July 09, 2010, 07:45:05 PM by 97fishmt »
halfcrazy
Re: 10'er is up for testing
« Reply #1 on: July 09, 2010, 07:59:26 PM »
Very good she looks great is that Rohn 45g or 55g looks like it should hold it up nicely
97fishmt
« Reply #2 on: July 09, 2010, 08:23:39 PM »
Yes a 45G with a hinge I made for tilting.
It works great.  I'll need to put a taller
tower stub up top to go more than 12'
but that's no problem now. I've raised
it and lowered it at least a dozen times
now since I put it up last fall.  I'm not
using turnbuckles and it hasn't been a
problem adjusting the guy's with a cable
puller. I don't know if they stretch or not.
I placed my tower points as accurately
as possible to avoid strain.  It works awesome.
defed
« Reply #3 on: July 09, 2010, 08:27:55 PM »
what are you using for the gin pole?  do you have wider pics of the tower being raised?  i have a heavier rohn tower (freestanding, 5' base) that i want to tilt.  i was a bit worried about how the tower would react to being horizontal, but if your lighter tower w/ same turbine manages, there is no reason the heavier one shouldn't.
97fishmt
« Reply #4 on: July 09, 2010, 08:37:20 PM »
For my 65' 45G tilting tower I am using 30' of
3" schedule 40 with 3/8" galvanized guy wires
out 30' from the base.  And two single block
pulleys to pull it up with 7/16" cable through
a grip hoist.
This was just putting it up to build it in sections
I have since moved the lifting cables out to the lift block.
« Last Edit: July 09, 2010, 08:57:06 PM by 97fishmt »
