Author Topic: Desulfator. can bobbin inductors be used instead of toroid  (Read 8021 times)
Re: Desulfator. can bobbin inductors be used instead of toroid
« Reply #33 on: August 15, 2010, 04:34:14 PM »
Because if you want a nice heavy current into a battery, you are going to have to boost that 17 v supply to more like 170 to get tens of amps into a sulphated battery.
Caps would work too, but then you have to switch the full current into the battery, while holding off a high voltage. using a coil lets the current build slowly at your voltage of choice and dump that current through a cheap diode quickly.  I've seem some circuits that use SCRs for this as well.
DragonFly III
« Reply #34 on: August 18, 2010, 11:03:24 AM »
Any schems on a circuit with Caps.
DragonFly III
« Reply #35 on: August 18, 2010, 11:04:41 AM »
Duh, 2 post back is the schem site
DFIII
