Author Topic: VAWT new proto-type  (Read 250270 times)
GoVertical
Re: VAWT new proto-type
« Reply #495 on: June 24, 2012, 02:25:47 PM »
Hi, do you have a working prototype?
kilroyOdin is not here ;)
SEMPER FEROX
GoVertical
« Reply #496 on: July 22, 2012, 02:02:19 PM »
Hi, photos of new proto board layout. I added a terminal for the amp brake out connection on the power modules. The brake out location is for making current measurements at the input and is also the location of the fuse at the input. I still have to add mosfets and diodes. I should able to test in a few days.
SEMPER FEROX
GoVertical
Re: VAWT new proto-type, blade rotor configuration
« Reply #497 on: September 01, 2012, 08:53:26 AM »
Hi, this is the style blade I can fabricate. The C shape will have end caps.
The big question is what style will have better performance at average wind speeds? Please cast your vote, A, B, or C.
It is a election year.   8)
SEMPER FEROX
GoVertical
« Reply #498 on: September 08, 2012, 08:56:58 PM »
Hi, heat forming Coroplast for new blades. If you keep the heat gun in one place to long the Coroplast does melt.
SEMPER FEROX
GoVertical
« Reply #499 on: September 13, 2012, 12:18:59 PM »
Hi, making progress. Yes you guessed correct, no wind. 3 more blade to go.
SEMPER FEROX
GoVertical
SEMPER FEROX
« Reply #501 on: September 17, 2012, 09:46:24 AM »
I see the winds gods are still toying with you!  ;)
GoVertical
Re: VAWT new proto-type,DIY HUB
« Reply #502 on: September 24, 2012, 07:58:02 PM »
Hi, I completed hub design. I drilled the threads out of a 5/8 nut and added a set screw. I then mounted the nut in a case to found a hub that I can mount to any rotor. It is low cost and solves my availability problem. What do other projects use for a hub?
SEMPER FEROX
« Reply #503 on: September 28, 2012, 02:22:12 PM »
... What do other projects use for a hub?
... Hubs, usually...  ;)
Axle hubs, trailer hubs, ATV hubs, bicycle hubs, motorcycle hubs, gear hubs... take your pick!
GoVertical
« Reply #504 on: November 25, 2012, 08:21:51 AM »
test photos, using TurboCad to reduce photos for upload.
« Last Edit: November 25, 2012, 08:29:07 AM by GoVertical »
SEMPER FEROX
GoVertical
« Reply #505 on: December 20, 2012, 01:37:42 PM »
test photo
« Last Edit: December 20, 2012, 03:18:11 PM by GoVertical »
SEMPER FEROX
GoVertical
« Reply #506 on: December 20, 2012, 04:04:23 PM »
Moer photos
SEMPER FEROX
GoVertical
« Reply #507 on: December 21, 2012, 06:02:03 AM »
Hi, I completed the first blade with modification. I have to fabricate hole templates for faster fabrication. The blade seems to have the same structural integrity. Hopefully the quality of fabrication will improve over time.
SEMPER FEROX
GoVertical
« Reply #508 on: December 23, 2012, 06:29:44 AM »
http://www.youtube.com/watch?list=UUE--_X1h08StIiaSSxefTCg&v=KAtPFCCw9I4&feature=player_detailpage
Not a valid youtube URL
Hi, I am happy with the fabrication method and the materials being used. The large mast blade rotor bearing seem to being working well and provides structural integrity. The belt drive is adding a lot of load, the 1 to 4.25 ratio is to high for the blade size. The stock F&P can only be used if a affordable MPPT controller can be found. All the pieces to the puzzle are there I just have to find the correct combination. Reducing the belt drive ratio and finding a better blade configuration is the starting point. There are still a lot of options.
started V3 MPPT assemble
SEMPER FEROX
GoVertical
« Reply #509 on: January 25, 2013, 06:13:05 AM »
Test photos of VAWT crash
SEMPER FEROX
GoVertical
« Reply #510 on: January 25, 2013, 06:18:42 AM »
recent test results, stock F&P with 1 to 2.5 timing belt drive. Spring on pulley shaft allowed belt teeth to jump cogs on pulley. I removed the springs and I am waiting for wind to test again. I was able to repair VAWT crash.
test photo, max wind speed 19 MPH, 12 volt battery as test load
max wind speed 13 MPH, 12 battery as test load
« Last Edit: January 25, 2013, 07:01:19 AM by GoVertical »
SEMPER FEROX
GoVertical
« Reply #511 on: January 25, 2013, 06:55:49 AM »
test photo
SEMPER FEROX
« Reply #512 on: January 25, 2013, 10:00:24 AM »
From what I can see, it looks like you had an anchor failure?
GoVertical
« Reply #513 on: January 25, 2013, 12:52:34 PM »
Hi, yes the test foundation was weak, the board snapped and the VAWT came crashing down. I was watching it from inside, one moment it was fine I turned around and it was gone.  :o This project is a learning experience.
All fixed now and waiting for wind. :)
SEMPER FEROX
« Reply #514 on: January 25, 2013, 04:46:42 PM »
I know your pain :(! happens to me when testing new dump load controller settings and NiCd battery banks. :-(.
GoVertical
« Reply #515 on: April 30, 2013, 03:48:20 PM »
http://www.youtube.com/watch?v=fzP1hydH7O8e&feature=youtu.be
Project update. Dual blade configuration, hoping to remove load that transmission adds to the system
« Last Edit: May 26, 2013, 08:12:56 PM by JW »
SEMPER FEROX
GoVertical
« Reply #516 on: May 05, 2013, 08:09:20 AM »
video test ???
SEMPER FEROX
GoVertical
« Reply #517 on: May 26, 2013, 08:00:24 AM »
 No wind, no power. The Pgen is just for testing the circuit and maybe burn a few calories.  :)
http://www.youtube.com/watch?v=0OmLqlzypr8&feature=youtu.be
« Last Edit: May 26, 2013, 08:11:24 PM by JW »
SEMPER FEROX
brandnewb
« Reply #518 on: January 25, 2024, 12:46:59 PM »
Ok brother.
You seem to be next level!!!
I am hot on your trail yet I lack soo much of what you seem to know about.
If you are even still around here I would like to compare notes and see if we can get things stellar.
Maximum respect.
