Author Topic: Ugly Turbines  (Read 824 times)
Tritium
Ugly Turbines
« on: July 22, 2010, 03:45:07 PM »
I found this in the Lubbock, TX Thrifty Nickel yesterday. They are perhaps the ugliest I have ever seen and although I have not been there yet to quiz these guys I am planning to visit them for a good laugh since they are only 60 miles away. Definitely blade design and materials at its worst according to everything I have learned here and from Hugh P.  They don't even mention their alternator design.
http://www.endlesssupplyenergy.com/index.html
Thurmond
« Last Edit: July 22, 2010, 03:49:07 PM by Tritium »
Re: Ugly Turbines
« Reply #1 on: July 22, 2010, 04:27:06 PM »
My "Ugly 30" has just lost its claim to fame.
I never thought it would be de-throned as the ugliest I ever saw.
At least "Ugly 30" was reasonably efficient.
(this photo is rated NC-17 due to graphic ugliness.  View at your own discretion.)
http://www.otherpower.com/images/scimages/2050/ugly30efkabuckt.jpg
Rover
Re: Ugly Turbines
« Reply #2 on: July 22, 2010, 04:55:50 PM »
LOL..ghurd.. yep thats hmmm ....
On the other , Tritium, might be the photo angle, but it almost looks like the blades are inflatable
(..forget furling , just deflate your blades)
Rover
Re: Ugly Turbines
« Reply #3 on: July 22, 2010, 05:07:02 PM »
G!  Is that an non-EPA-approved use of toxic plastic waste?
(Was it more or less toxic overall before you emptied it?)
Tritium
Re: Ugly Turbines
« Reply #4 on: July 22, 2010, 08:02:07 PM »
I shot off a list of questions to the makers of the "ugly turbines". I will post when answers arrive. I even made many of the questions multiple choice to make it easier for them to answer. Their cheapest turbine (9' blades 3.5kw at 20mph they state) is only 10 grand and includes a tower. ::)
Thurmond
Tritium
Re: Ugly Turbines
« Reply #5 on: July 23, 2010, 08:47:02 PM »
I received this reply today: ( I am going to pay them a visit soon)
Mr Moore,
Thank You for your interest in our wind turbines,and I will do my best to answer your questions. I apologize that our web site is not well defined and we definately need to update. Let me explain that we have an original design and our new design and I will explain the difference between the two.
Our original design has a gear train with miter gears that connects blades to a drive line that goes through the middle of our tower to the base of the tower. A series of alternators (24 volt truck alternators) will then charge the battery bank which is then connected to grid tie inverters, this is why batteries and grid tie technology was both referenced to on our web site. Spur gears is applied to drive line to get appropriate speed for alternators for specified output. The mass direction (larger units)is controlled with a PLC (programmable logic controller)by using a 0-10 volt potentiometer connected to a wind vain. The mass has 48 points for 360 degree rotation,with each point having a reference to the potentiometer,for example point 1 being 0 to .208 volts, point 2 being .209 -.417 volts etc. The PLC then energizes a gear motor to turn the mass to appropriate direction. A time delay is programmed into the PLC to eliminate constant adjusting of the
 mass during wind gust that can change wind direction momentarily and then return to orginal direction, therefore wind has to change direction for 5 seconds before gear-motor is energized. Our blade material is galvanized metal attached to a galvanized steel frame, with the surface area being the concept of creating massive torque. Also using galvanized blades compared to fiberglass we have eliminated stress crack problems that has been reported with fiberglass blades. We have two basic ways incorporated for high wind speed issues,first with our blade design as wind comes off the front of the blade it will catch the back of the oncoming blade since we use so much surface area, therefore making it self governing. The second way is the PLC is monitoring rpm and is programmed to start turning mass away from direct wind which is our directional brake.
Our new design has many of the same designs as our original, but also includes many changes. We were assisted by an engineer with a masters in mechanical engineering from Texas Tech and created a more efficient and productive units compared to our original design. We changed our generating method to a low rpm AC three phase permanent magnet generator that is mounted on the mass instead of at the bottom of the units.This eliminates the series of miter gears and having to create such a high speed increase needed for previous alternators. This generator lets us start producing at even lower wind speeds and uses less torque to produce electricity this also eliminates the need for a battery bank.The current is then run through a controller which is used as an rectifier and monitors for over voltage due to high wind speeds. This now gives us three ways of dealing with high wind speeds, also if controller has excess voltage it is channeled into a load dump
 protecting the grid tie inverter from an over voltage situation.
Some other features of our turbines are that our frames are galvanized steel. Units are erected with a hydraulic ram therefore greatly reducing installation cost by not requiring cranes or excessive equipment to erect.
Some of our units weigh up to 6000 lbs with 20,000 lbs of concrete in the base, so they are not lightweight units.
We are a new company and currently we only have a prototype that we are converting to our new design and it is the unit we have used to test different mass cofigurations. We have made presentations to some municipals and are being proposed for purchase in new fiscal budget year which will start in October. If approved we will have some large units in operation. I am attaching a short video of one of our test masses running in 6 mph wind, and we also engaged the directional brake so you can see how effective it works. We have also applied this brake in extreme high winds with the same results.
I hope I have answered all of your questions, if not please feel free to contact me by e-mail or telephone.
Thanks again for your interest and thank you for your time and consideration
Carl Nixon
Endless Supply Energy
(806) 577-9146
Re: Ugly Turbines
« Reply #6 on: July 23, 2010, 09:06:40 PM »
OK, I will byte.
What does he mean by "energizes a gear motor to turn the mass"?
Mast?
Seems a complicated machine.
Anyway just curious on that mass thing.
B529
Re: Ugly Turbines
« Reply #7 on: July 23, 2010, 09:22:17 PM »
Just think, some poor sap might actually be scammed into buying one of these slices of poop.
I wonder if he'll be in business in 6 months? Maybe, but under a different name in a different state.
Old F
Re: Ugly Turbines
« Reply #8 on: July 23, 2010, 10:21:52 PM »
OK, I will byte.
Mast?
Tom could they be referring to a big steaming mass of something ::) :D
Re: Ugly Turbines
« Reply #9 on: July 24, 2010, 07:13:15 PM »
If you look on their Products page they have some really High quality CADD drawings but no pictures, I don't think that these machines exist outside of a computer program. They have some pictures on the Home Page but they are tiny without detail, I don't think there is a generator on those towers, just props.
And yes TomW, in their written response to Tritium you would replace the word Mass with the word Mast in all instances.
fabricator
  • My smoke got out again
Re: Ugly Turbines
« Reply #10 on: August 03, 2010, 07:58:11 PM »
OK, I will byte.
Mast?
If you can't dazzle em with brilliance, baffle em with bull poop, or another favorite among flim flam men, the O&M strategy, obfuscation and misdirection, Oh and Glen, let's not be so hasty in our decision that your ahhhhhhh thing, has been dethroned, I personally think it is still firmly in place.
arrick
Re: Ugly Turbines
« Reply #11 on: August 05, 2010, 10:03:34 AM »
   Yeah,that thing is butt ugly.If they actually build a working model,it's gonna have more moving parts than the space shuttle.And I guess a 30ft driveshaft from the gear box to the "truck alternators".
 Here's a pic of their biggest one.
                http://www.endlesssupplyenergy.com/12KW35D.html
    Arrick
Re: Ugly Turbines
« Reply #12 on: August 05, 2010, 10:12:04 AM »
Golly, that thing looks like it was built by committee and by folks with different languages getting paid based on "final cost".
Just goes to show how silly things can get when you over think the plumbing.
Just my early in the day opinion. Likely shared by a handful of the other crotchity old farts.
fabricator
Re: Ugly Turbines
« Reply #13 on: August 05, 2010, 05:23:04 PM »
Hey! I represent that remark! >:(
Re: Ugly Turbines
« Reply #14 on: August 05, 2010, 05:42:36 PM »
based on "final cost"... being low or high?
Looks like what they saved on blades, etc will be used up on bearings.
I figure the bearing cost at between 2 and 3 gazzillion dollars.
Looks like nobody compared Betz Law to the swept area of that, or that with a simple single prop.
fabricator
Re: Ugly Turbines
« Reply #15 on: August 05, 2010, 06:14:41 PM »
I'm pretty sure those yahoos would think betz laws has something to do with casino gambling.
