Author Topic: switch mode power supply ??  (Read 2709 times)
bob g
    • microcogen.info
« on: August 12, 2010, 01:08:58 AM »
as part of a purchase of some generator heads, i came upon a switch mode power supply
the specs
3phase input 208/240 at 50,60,400hz
output 5volts dc at 500amps
i can't imagine a use for them myself, mainly because i have no way of adjusting them up to something more
usable like 12,24 or 48volts
maybe someone in metal plating could put them to use?
any creative idea's here?
bob g
Janne
  • Country: fi
  • Turbiini
    • My image gallery
Re: switch mode power supply ??
« Reply #1 on: August 12, 2010, 03:50:31 AM »
Mayby you could turn it into a rust removing tool for huge parts =) Like for an entire barge etc..
http://www.stovebolt.com/techtips/rust/electrolytic_derusting.htm
« Reply #2 on: August 12, 2010, 07:25:01 AM »
If it was single phase it would be fun to mess with.  No 3 phase here except in the "industrial" area in town. I need a 5 volt DC supply but only a few milliamps needed for it.
Toss it on FeeBay ;D
I sell the weirdest stuff on there.  Funny what folks will buy online you would never sell or even give away otherwise.
That would be a truly industrial strength USB power supply.
bob g
    • microcogen.info
« Reply #3 on: August 12, 2010, 07:55:43 AM »
i couldn't think of a good use for it, and thought i would ask here first
before tossing it.
it might have some useful goodies inside, but quite frankly i am buried in useful goodies as it is.
guess i will put it under the bench and let it simmer there a while, who knows maybe in the next decade
i will come up with some use for it.
bob g
« Reply #4 on: August 12, 2010, 08:07:40 AM »
hang on to it.
I recently scored two, 4-6 vdc 300 amp single phase supplies on ebay for all of $50, was the sole bidder.
The input filter caps should be big enough to run it at >150 amps on single phase power
