Author Topic: Anemometer install  (Read 2925 times)
Janne
  • Country: fi
  • Turbiini
    • My image gallery
Anemometer install
« on: September 05, 2010, 01:10:03 PM »
Today I got around to installing the anemometer I received earlier this week. The anemometer I ordered was this; http://www.inspeed.com/anemometers/Vortex_Wind_Sensor.asp
To mount the sensor, I welded a bracket from some square tubing, and just screwed it on to the wooden part of the tower. Before I took the tower down, I also made a new tower rest from a lenght of 2x4. That was a lesson learned earlier this summer, the old tower rest (oil drum) was too short, so that the rotor only had room to come to rest at one position. Of course the last time I didn't remember that, so one blade struck ground, and splintered off about 30cm from the tip. I was able to mend the blade by gluing the tip back on, since it was not completely broken off, and it splintered at a quite shallow angle. So far it's been holding on, but I already have new blanks available to carve when I get the time and motivation to re-do them.
While the tower was down, I also gave it a new coating. The formula I've been using is 1 part of heat treated linseed oil mixed with 3 parts of pine tar, and heated until it becames thin enough to apply. It seems to be holding quite nicely in the enviroment.
The display unit for the anemometer is made from 7-segment displays. Inside is a picaxe-microcontroller, that does the windspeed calculation based on the pulses given by the anemometer. It also handles the display driving. Anyone interested more about the detailed circuitry or program can pm me, and I can e-mail them. I'm also planning to log the windspeed, along with power output from the turbine. Then, after I get the mppt controller installed, I can compare the new performance of the turbine.
BrianSmith
Re: Anemometer install
« Reply #1 on: September 05, 2010, 04:01:24 PM »
That looks pretty good.  I am going to checkout your anemometer you ordered for use in something I'm tinkering with.  Good luck.
Rover
« Reply #2 on: September 05, 2010, 04:11:42 PM »
I like it !
I have a lacrosse wireless  anenometer (part of a larger wireles package, really only good for outside temp/ barometric/ wind direction)  on my tower , which is pretty much useless for wind speed  because of the slow update time 1-2 minutes,  obviously an effort to conserve battery power.
I'd like to pair an anenometer such as yours with a zigbee and get (near) real time wireless  .
Looks cool
Rover
bj
« Reply #3 on: September 05, 2010, 06:17:22 PM »
  Rover, not to steal the thread, but I have a Lacrosse as well, and out of laziness I built a battery box so that I could use C cells.  Update time got better.
  Usually every 30 sec. unless it's -40.
bj
Lamont AB Can.
Rover
« Reply #4 on: September 05, 2010, 06:36:11 PM »
Sounds like you made an eficient change bj.  I'm still thinking of using a somewhat standard anenometer such as what Janne used, couple to a small micro and a ziig bee.  Should be able to get readings down to a sec.
Rover
Janne
  • Country: fi
  • Turbiini
    • My image gallery
« Reply #5 on: September 06, 2010, 06:14:23 AM »
Rover,
What zigbee boards do you use? I've been using xbee modules from maxstream. They work nice, but are a bit on the pricey side, so I'm on a lookout for a cheaper alternative.
Zigbee would be good in this sort of application, however I had the signal cable already buried and brought inside to a terminal so for me the wired solution was very easy.
Rover
« Reply #6 on: September 06, 2010, 07:50:15 AM »
Hi Janne,
I'm currently using Xbees  - Zigbee 2.4 standard (Maxstream) , yeah they area bit pricey but they do work well.
Rover
