Author Topic: Wind/Solar system.  (Read 2234 times)
Windshack
Wind/Solar system.
« on: September 18, 2010, 10:01:39 AM »
Hi Guys
Just a few questions!!!
1.  I have a 48volt battery bank(four 12v in series), if i connect a 12v solar panel to one battery will it charge all four batteries.
2. I also have a 48 volt wind generator so need a dump load. Can i use a small 12v charge controller(connected to one battery) to operate a 48volt dump load.
Philip
Re: Wind/Solar system.
« Reply #1 on: September 18, 2010, 10:33:41 AM »
Hi Guys
Philip
Philip;
In a word NO
Rover
« Reply #2 on: September 18, 2010, 10:37:20 AM »
Simply stated, in order to charge the batteries, the charge source must provide a higher voltage than the battery bank voltage. !2v is not higher than 48V.
Rover
WindriderNM
    • WindriderNM
« Reply #3 on: September 21, 2010, 01:07:13 AM »
some type of switching system using electronic switches or relays could be made to switch the 12v between the batteries charging one at a time.
Windshack
« Reply #4 on: September 21, 2010, 01:59:05 PM »
I was thinking more about having 2 solar panels connected to each battery, so a total of 8 panels.
  • Moderator
« Reply #5 on: September 21, 2010, 02:14:00 PM »
Then just use a standard configuration, instead of 2 to each battery.
The answer to your next question-
Those 12V controllers driving a 12V solenoid to dump from all 48V are not a good idea.  Not at all.
Be better off with one of my controllers monitoring 12 or 24V, and using different power fets.
Or could use my controllers, 2 x 24V or 4 x 12V, and treat them as individual battery subsections.
The best idea would be a controller actually made for 48V by a REAL controller company,
a company that would not tell someone to monitor 1 battery in a 48V bank,
but I get the feeling you don't want to go that route due to cost.
