Author Topic: Homemade wind turbine 2KW  (Read 39502 times)
spitfire
« on: October 09, 2010, 03:32:05 AM »
Hello, I'm new to the forum. Since so many people in recent years are passionate about alternative energy, especially wind energy prodatta. For all these people who want to try their hand at building small homemade wind turbines, helping to dispel all the many uncertainties and many doubts, I suggest that my speech to share with you my experience so that it can be useful to all.
I built a horizontal axis wind turbine with 2 ml kWp. 3.80 in diameter with neodymium magnets alternator 30x50 16 +16 N Grade 42 and 12 coils of 75 turns with wire Ø 1.80 mm. The stator is star connected and the system is 48 Volt
Here are the photos:
THE BLADES
Metal frame
The stator
Rotors
The alternator assembly
The electrical collector
The blades eqilibratura
In final position
A first taste of 1 KW
In Annex I attach my whole project with Autocad at this link: http://energiaalternativa.forumcommunity.net/?act=Attach&type=post&id=280224661
At this link:  http://www.youtube.com/watch?v=ZAOY6DS6luk you will find a precent my realization.
Forgive my bad English, I write from Italy with the help do google translator.
Un Saluto a tutti :)
SpitsFire
« Last Edit: October 09, 2010, 03:47:24 AM by spitfire »
IPSA SCIENTIA POTESTAS EST
gotwind2
  • ben[at]gotwind.org
Re: Homemade wind turbine 2KW
« Reply #1 on: October 09, 2010, 04:46:01 AM »
A superb job done there, well done.
I like the magnet retaining method, it should allow some cooling of the stator.
Is that a plant pot as the nose cone?  :D
One of the best DIY machines I've seen for a long time.
freejuice
« Reply #2 on: October 09, 2010, 05:06:10 AM »
very very nice!
 Your blade work is excellent!
 In fact everything is well made!
vawtwindy
« Reply #3 on: October 09, 2010, 07:51:00 AM »
Congratulations spitfire,  its really good creative work too..
endless hurdles.
« Reply #4 on: October 09, 2010, 07:55:33 AM »
"IPSA SCIENTIA POTESTAS EST": indeed.  Not to mention some machining skills (which I sadly lack).
Both your English and your craftsmanship are enviable.
prasadbodas2000
  • Country: in
« Reply #5 on: October 09, 2010, 11:23:37 AM »
A real professional and fantastic build. Sliprings are cool. What kind of dump load controller and MPPT if any - have you set up?
The video on utube is super.
(The dragon (is that correct?) in your signature and on the machine tail - sounded like you are from china /of chinese origin.)
« Last Edit: October 09, 2010, 11:29:28 AM by prasadbodas2000 »
luv2weld
« Reply #6 on: October 09, 2010, 11:41:17 AM »
Great work!
And an excellent presentation.
Welcome.
Thanks for sharing it with us.
Ralph
« Reply #7 on: October 09, 2010, 08:39:31 PM »
Spitfire,
Welcome to the forum!
English isn't a problem at all - especially when the pictures show excellent handiwork.
Thank you for posting and we all look forward to knowing more about your progress.
Tom Sullivan
    • U.P. Solar Solutions
« Reply #8 on: October 09, 2010, 09:55:12 PM »
Very nice looking turbine.  Your workmanship is clearly excellent.  Congratulations on completing your project.
spitfire
« Reply #9 on: October 11, 2010, 03:47:13 PM »
Hi, thank you all for the compliments, you have encouraged me to do even better.
hello gotwind2
Yes, I made the nose with a flower vase  ;D
hello  prasadbodas2000
The charge controller I bought from you in America, is the Tristar TS60 Mornistar.
Since I was small that the figure of the dragon has always tickled my fancy. So I'm not Chinese but true Italian. :)
In short, I will publish a movie on youtube to demonstrate the efficiency
Greetings to all
Spitfire
« Last Edit: October 11, 2010, 04:03:00 PM by spitfire »
junioroo7
« Reply #10 on: October 15, 2010, 04:03:32 AM »
@ spitfire... Good work . I liked the way you build it, very clear . It looks you are very profesional ..
   I have some questions becouse you didnt put to many details.
- what size where the magnets ?
- what size here the conection roods .. like the diameter..
- and  at how much rpm or wind speed you got 48v/30A like in the picture. .
Multo Bene ..
   Ciao ..
fp_11
« Reply #11 on: October 21, 2010, 07:27:41 AM »
Hello
Where I can buy panel meters like those you use on your wind turbine?
« Reply #12 on: October 21, 2010, 03:52:07 PM »
Those are DIN style panel meters and are common in Europe. I assume they are available in N.America.
Unless we know where you are it is not much use offering suppliers although Farnell and RS stock them in UK and I believe they have outlets in N.America.
This may be a convenient place to congratulate Spitfire on the excellent workmanship and presentation.
« Reply #13 on: October 21, 2010, 06:17:27 PM »
Beautiful workmanship and turbine.  I did note that it appears that you did not cover the plated neodymium magnets in your build.  From my experience the plating is not perfectly water proof and with suficient moisture, the magnets will begin to rust, causing the plating to bulge and then flake off as the sintered material underneath oxydizes.  I have been to the southern portions of your country, but never in the north where it appears that you are at.  Thank you for posting your turbine.
Google's Italian translation:
Bella lavorazione e turbina. Ho fatto notare che sembra che tu non coprivano i magneti al neodimio placcato nel costruire. Dalla mia esperienza il fasciame non è perfettamente impermeabile e con umidità suficient, i magneti inizierà a ruggine, causando la placcatura a gonfiarsi e poi sfaldarsi come il materiale sinterizzato sotto oxydizes. Sono stato alle parti meridionali del paese, ma mai nel nord, dove sembra che ci si trova. Grazie per aver postato un turbine.
« Reply #14 on: October 21, 2010, 10:50:55 PM »
Nice work.
One point:  I expect the copper brushes working against the copper slip-rings to eventually weld and tear.  I'd replace the brushes with something made of graphite.  You should be able to find quite an assortment of materials in any shop that handles large DC motors.
spitfire
« Reply #15 on: October 24, 2010, 03:58:47 AM »
Multo Bene ..
   Ciao ..
Hello, the magnets are mm. 30x50x10 N42 magnetization.
But I'm not 30 A 20A, that power was reached at about 150 rpm.
The other question I could not understand it, sorry.
Greetings
SpitsFire
spitfire
« Reply #16 on: October 24, 2010, 04:06:04 AM »
Richhagen Hello, thank you for the compliments and the suggestion for the magnets.
I can tell you however, that the magnets were treated with a thin layer of epoxy trasparente.La my area where I live is in southern Italy, though it seems, I am in the province of Avellino, one hour from Naples.
A cordial greeting
SpitsFire
spitfire
« Reply #17 on: October 24, 2010, 04:11:21 AM »
Nice work.
Hello Ungrounded Lightning Rod, As for brushes, but do not appear, but are real and his own brushes for Bosch starters, maybe the picture a bit blurry and the color you have but deceived
I put the photo of the original brush before the change:
Greetings
SpitsFire
« Last Edit: October 24, 2010, 04:13:15 AM by spitfire »
« Reply #18 on: October 24, 2010, 05:46:17 PM »
Now that you've shown me the brushes I can make them out in the original photo.  Looks good.
That's one fine machine.
« Reply #19 on: October 24, 2010, 09:19:17 PM »
Hi again Spitfire,
Now I see you are in Italy.  Do you know Antonio Cecere?  He has taught wind turbine construction workshops in Rome, like Hugh Piggott does.
http://www.webalice.it/acecere48/index.htm
I have corresponded with Antonio, from time to time over the years.
If you have never met him, I bet that he would be very interested in your project!
Ciao
spitfire
« Reply #20 on: October 25, 2010, 03:03:34 AM »
Hello SparWeb, I have been in contact via the web with Antonio Cecere. He has translated from English into Italian on the last hand of Hugh Piggott. The same Mr. Cecere gave me some advice on the implementation of my wind turbine.
Greetings
SpitsFire
« Last Edit: October 25, 2010, 03:06:08 AM by spitfire »
artv
« Reply #21 on: October 25, 2010, 08:41:58 PM »
Hi Spitfire beautiful work.....this might be the most stupid question you've ever heard , but why do you have slip rings and brushes?........sorry ....artv
« Reply #22 on: October 26, 2010, 12:25:10 AM »
Hi spitfire ,
What kind of wood is used in your wind turbine?
spitfire
« Reply #23 on: October 26, 2010, 01:43:15 AM »
Hi artv, I used the slip rings and brushes , because in my case, it is the twisted cord.
Hi spitfire ,
Hi willib I used cedar wood matured, I think is the best.
Greetings to all
Spitsfire
spitfire
« Reply #24 on: November 06, 2010, 12:15:31 PM »
Hi, I am proud to inform you that the Australian friends, lovers of the wind, have published my realization in their home.
http://www.thebackshed.com/windmill/home.asp
A warm greeting from Italy '
SpitsFire
« Reply #25 on: November 06, 2010, 01:24:12 PM »
SpitsFire
Bravo!
And rightly so!
Very nice example of what can be accomplished in home wind power.
Thanks for the share.
Yes, Knowledge itself is power.
And:
La risposta soffia nel vento
Got that off Google I only speak English and Bad English. ;D
Premji
« Reply #26 on: March 26, 2011, 12:25:20 PM »
I'm doing in my free time generator, what kind of steel is good for base for neodimium magnets i used (pl noumber) - 1,4301 and it dosn't hold it at all.
Looking forward to recive any message.
What sort of resin did you use to make stator? and did you painted it red or is it orginal resin color?
All the best
spitfire
« Reply #27 on: March 26, 2011, 02:28:13 PM »
All the best
Hi
The rotor discs are of normal iron. The two-component epoxy resin, red. Is used to make flooring.
All the best
SpitsFire
