Author Topic: Off-grid night-light!  (Read 11012 times)
Re: Off-grid night-light!
« Reply #33 on: February 18, 2011, 03:17:48 AM »
Still going...  B^>
« Reply #34 on: February 18, 2011, 09:17:41 AM »
That's good to see!!
St. Louis dodged the bullet on the massive snow that went north to Chicago.
With the 70s and sunshine I finally saw the dump controllers actually dumping to the next setup.
Cheers;
« Reply #35 on: February 19, 2011, 06:17:04 AM »
Woooo!  A dump controller actually getting to do its thang!
My equivalent is seeing my big bank brought up to absorption voltage, even if only for a while, though I haven't yet had enough sun for it to get to float.
« Reply #36 on: March 05, 2011, 01:21:51 PM »
Still going!  So even on the ordinary NiMH AA cells this seems good for one charge for most of winter.  With the low-self-discharge NiMH cells presumably it could manage the whole of winter.
« Reply #37 on: March 08, 2011, 01:01:17 PM »
Noticed that battery voltage was down to 4.52V (from a nominal 4.8V), so decided to give it a quick charge from my off-grid system this evening, which is full to the top from a couple of days of good sun.
The NiMH charger is configured as a dump load, so will only come on when the SLA voltage is fairly high (around float voltage) and when I got back at dusk it was below that (but well above the lower/LVD threshold).
Evil trick of the day: I put my mobile next to the dump-load circuit and called it from the land-line for not even a full ring.  The RF noise induced was enough to turn the dump on and the NiMH cells are now charging merrily!  %-P
