Author Topic: some questions about pm motors  (Read 2485 times)
whatusernamesareleft
« on: November 04, 2010, 12:38:45 PM »
I was wondering if I can group like 2 pm motors together for a wind or ped gen project,  or would this not work?  Possible vertical axis setup with a pm motor at the top and bottom.  and I was thinking about doing a 2 motor setup run by the same belt for a ped gen.  Can I setup like a amp meter gauge on this stuff some how too?  The motor specs are 24vdc and 2040 rpms 10amps.
snake21
Re: some questions about pm motors
« Reply #1 on: November 04, 2010, 02:52:02 PM »
i think that your motor is not suitable to be used for 12v or 24v.generaing 12v around 1000rpm is difficult.wind gen best rpm for cut in is 300 or below.ped gen can do it but you will have to connect the motor shaft to the wheel itself,not to the sprockets
